2000 Trooper: Tranny Down!! #426906 03/30/04 11:19 PM
glock Offline OP
Without ANY warning whatsoever! <img src="/forums/images/graemlins/shocked.gif" alt="" />
47K...Went to pull away from a light and she felt like someone was holding me back...or like a brake was hung up...or the emergency brake was on... <img src="/forums/images/graemlins/baby.gif" alt="" />
Then she flat out wouldnt move without revving up the RPM's...Which I of course did NOT want to do!
No leaks to be found. Towed to Isuzu, under warranty, but what the !@%& could this be? <img src="/forums/images/graemlins/confused.gif" alt="" />
2012 Jeep Liberty
2000 Trooper 3.5, LS/Burgandy & Grey(O.B.T.2)...<img src="/forums/images/graemlins/cheers.gif" alt="" />
I WAS down with O.B.T. '88 Trooper II
("Old Blue Trooper!" said my kids!...)
Re: 2000 Trooper: Tranny Down!! [Re: glock] #426907 03/31/04 03:07 AM
bob large Offline
Sorry to hear that. I know how having car problems can be an absolute nightmare.
As to a diagnoses. <img src="/forums/images/graemlins/confused.gif" alt="" />
Sounds like the torque converter is not working. Possibly extreme low fluid level? Or an output bearing on something (transfer case, tranny, rear diff) is sized. Maybe the parking brake is sized, the cable got kinked, or the parking brake pads broke in peaces and are jamming up the drum. Or a wheel bearing is completely seized causing drag. Or the clutch plates in the transmission are not disengaging.
ItÆs really hard to guess without looking at it, and having more details. It should be fairly obvious when you get it up on a rack and start spinning things. Hope it all works out.
Steve C
Re: 2000 Trooper: Tranny Down!! [Re: glock] #426908 03/31/04 03:10 AM
Could be a computer error and that the tranny is defaulting to 'limp mode'...which sticks it in 3rd gear. 3rd gear starts feel like someone is definitley holding you back until you're way up to speed. Hope it's not serious. Keep us updated!
Re: 2000 Trooper: Tranny Down!! #426909 03/31/04 06:43 AM
A
Amigo-2k Offline
my guess. the shift range sensor went bad.
Re: 2000 Trooper: Tranny Down!! [Re: glock] #426910 03/31/04 07:56 AM
taro Offline
just curious...but did any check transmission/engine lights come on? if not, you might check the alternator. might transmission went into limp mode once. no warning lights were tripped. turns out my alternator was not putting out enough current under load. good luck, taro
Re: 2000 Trooper: Tranny Down!! [Re: glock] #426911 03/31/04 06:23 PM
bob large Offline
You didn't put it into "winter" mode did you? <img src="/forums/images/graemlins/drunk.gif" alt="" /> That will keep you out of 1st and start you off in 2nd gear. ItÆs a little button on the center consol next to the "power" button.
Steve C
Re: 2000 Trooper: Tranny Down!! [Re: bob large] #426912 03/31/04 07:19 PM
When mine goes into Limp-Mode, which is pretty often now. You should be able to shift manually, until it can be reset. Mine usually needs to turn off the engine restart to get it working normally. If your tranny gets a faulty electrical signal it will put itself into Limp-mode, so you might just have a ground wire that's worked loose.
Probably worth checking into - Also, I second the opinion to check out your alternator. Get a cheap volt meter and check voltage across the battery terminals with the engine running and with the engine off.
Good luck
-Robert
1993 Rodeo 3.2l Auto Tranny
Re: 2000 Trooper: Tranny Down!! [Re: glock] #426913 03/31/04 07:55 PM
glock Offline OP
Thanks guys, but when I say she wouldnt move, she wouldnt ENGAGE without reving her up and then would suddenly do so accompanied by some ugly clunking and grinding... <img src="/forums/images/graemlins/shocked.gif" alt="" />
2012 Jeep Liberty
Re: 2000 Trooper: Tranny Down!! [Re: glock] #426914 04/01/04 06:03 AM
bob large Offline
Ohh... not good at all. <img src="/forums/images/graemlins/shiner.gif" alt="" /> Major tranny problem! Defiantly tranny, or TQ. Possible gearing, clutch plates? I don't know, IÆm not a transmission dude. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
I just spent 1250, getting my transmission fixed. Not pleasant at all. <img src="/forums/images/graemlins/barf.gif" alt="" />
Steve C
Re: 2000 Trooper: Tranny Down!! [Re: bob large] #426915 04/01/04 11:43 PM
glock Offline OP
You, like I, must be a 2nd owner, then...I'm still under the 5 year, 60K warranty...Were you over on the miles? <img src="/forums/images/graemlins/frown.gif" alt="" />
2012 Jeep Liberty
PHP: 7.4.33 Page Time: 0.019s Queries: 16 (0.014s) Memory: 0.6399 MB (Peak: 0.7651 MB) Data Comp: Off Server Time: 2026-11-18 22:35:25 UTC
