Page 1 of 4 1 2 3 4
Steering: Strongest idler arm you can get #428077 04/01/04 11:24 PM
Nitteberg Offline OP
Made off a steering box
http://nitteberg.com
-83 Pajero SWB Soft Top 2,3TD
35x14,5x15 PitBull Rocker
Bodylift, LSD, PTO-winch, Intercooler, 2.85 gear's
Gen2 upper a-arms, flipped and raised ball
Re: Strongest idler arm you can get [Re: Nitteberg] #428078 04/01/04 11:28 PM
LandRaider Offline
Sweet!!! I bet that is a hoss!!
Re: Strongest idler arm you can get [Re: Nitteberg] #428079 04/01/04 11:55 PM
Interesting... And I have and extra box...
Re: Strongest idler arm you can get [Re: MontyMcV] #428080 04/02/04 05:54 AM
Re: Strongest idler arm you can get [Re: Nitteberg] #428081 04/02/04 06:04 AM
KrzyDav Offline
GREAT IDEA!!!
I'm concidering replaceing my '89 V6 2 door's , leaky at the top box, with a '90 - '91 lwb , which bolts up and is --ten times beefier-- than mine ,and has only a slightly different ratio.
Know I know what to do with the old box. Too bad I just bought a new arm on Ebay,,DUH.
Junk Yard Dog
dave h.
Re: Strongest idler arm you can get [Re: Nitteberg] #428082 04/02/04 06:04 AM
Kevin C Offline
I like it....! I think this qualifies as a first.
For sure this is the first time I have seen it tried.
Kevin
Re: Strongest idler arm you can get [Re: Kevin C] #428083 04/02/04 06:11 AM
DaphneD Offline
I've got a spare gearbox too, and now the gears are really turning in my brain! It looks like the top of that box has been shaved in half. Just curious as to why that is? Would there be any sense in making a power gearbox idler arm?
Re: Strongest idler arm you can get [Re: DaphneD] #428084 04/02/04 06:47 AM
Kevin C Offline
I am more surprised it took so long for this to get tried.. I had forgotten about it. It was knocked around as an idea about 6 months ago.
But no one till now stepped up to the plate to actually do it.
Kevin
Re: Strongest idler arm you can get [Re: Kevin C] #428085 04/02/04 02:55 PM
Hello
I did this one year ago, and it is shaved off to fit!
Re: Strongest idler arm you can get [Re: Kevin C] #428086 04/02/04 03:15 PM
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6411 MB (Peak: 0.7608 MB) Data Comp: Off Server Time: 2026-11-03 23:05:50 UTC
