Need help with Supercharger torque specs. and tightening sequence... #428702 04/03/04 03:23 AM
Marc M Offline OP
I plan on installing my Supercharger one day next week since I am on vacation. The only thing I need now is the torque specs on the housing itself, and the tightening sequence. Anyone able to scan the oem manual for the intake plenum stuff for me ???
Any help would be greatly appreciated...
Thanks
Marc
'06 Tacoma Dbl-cab, 4X4, V6, 6-spd, SR5/TRD....
'90 4Runner 4X4 SR5 5-Spd
'86 Shortbed 4X4 5-Spd, SAS'd ASAP
'82 Supra 5-Spd
Take your automatic and "Stick" it........
My Web Album in Progress
Re: Need help with Supercharger torque specs. and tightening sequence... [Re: Marc M] #428703 04/05/04 06:02 AM
Mark in AZ Offline
Toyota Moderator
Did you get it installed? Still need the torque numbers?
Exploring in a T4R Ltd V8
Re: Need help with Supercharger torque specs. and tightening sequence... [Re: Mark in AZ] #428704 04/05/04 06:38 PM
Marc M Offline OP
Yes, I still need them. I would really appreciate it if someone would post up the numbers and sequence....
Thanks
Marc
'82 Supra 5-Spd
Re: Need help with Supercharger torque specs. and tightening sequence... [Re: Marc M] #428705 04/06/04 08:10 AM
Mark in AZ Offline
Toyota Moderator
No sequence is specified.
Here's the '01 FSM text:
Install intake air connector assy (the lower part)
Install with a new gasket, 3 bolts, and two nuts
Torque: 18Nm, 13 ft.lbf
Install the DLC1 to the bracket (the diagnostic connector ? )
Install the ground strap to the intake air connector with the bolt.
Connect the fuel return hose.
Connect the vacuum sensing hose to the fuel pressure regulator.
Install the engine wire with the bolt.
Install air intake chamber assy (the top part)
Install with a new gasket, 4 bolts, and 2 nuts
I hope that's what you needed....
Re: Need help with Supercharger torque specs. and tightening sequence... [Re: Mark in AZ] #428706 04/06/04 04:26 PM
Marc M Offline OP
Thank you very much, I can now go about my endeavor. The fuel light is on, so I guess I better take out a loan and fill up the tank. This may me a bad time to have to use high octane fuel at almost $2.00 a gallon.
Marc in PA
'82 Supra 5-Spd
Re: Need help with Supercharger torque specs. and tightening sequence... [Re: Marc M] #428707 04/06/04 07:04 PM
Marc in PA
you should be glad your not in southern cali,91 octane is almost 2.50!!!!
best of luck with the supercharger,thou.Its only a matter of time before i get one... <img src="/forums/images/graemlins/evil.gif" alt="" />
d
Re: Need help with Supercharger torque specs. and tightening sequence... #428708 04/06/04 10:04 PM
Marc M Offline OP
At the Sunoco in town
$1.67 for 87
$1.77 for 89
$1.87 for 91,92, or 93 I don't remember
$1.97 for 94
The best prices are at the Costco near where I work, It's like $1.76 for 92 Octane.
Give or take a few pennies on all of the prices...
'82 Supra 5-Spd
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6141 MB (Peak: 0.7084 MB) Data Comp: Off Server Time: 2026-06-07 01:54:09 UTC
