AP 56" rear leaves? #37286 07/09/02 05:12 AM
Josh Offline OP
I was reading the ap site about the 56" leaves, and from what I was reading, I was a little confused. From what I am getting from the page, it seems that the 56" leaves will bolt right up to an 89-95 pickup. Is this true?
Josh
01 Chevy 2500HD: 6.0L gas 4x4 crew cab
in search of the next trail rig
Re: AP 56" rear leaves? #37287 07/09/02 07:10 AM
4Crawler Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Josh:
<strong>I was reading the ap site about the 56" leaves, and from what I was reading, I was a little confused. From what I am getting from the page, it seems that the 56" leaves will bolt right up to an 89-95 pickup. Is this true?</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Not quite, you'll still need to place new spring hanger about 5" forward from stock. You can retain the existing shackle hanger in back. The stock '89 springs are 51" long, and the extra 5" on the longer springs is all in the front half.
I'm running 56" Alcans on an '85 4Runner and only did the front hanger, running the stock shackle hanger and a 3.5" longer shackle:
56" spring install
Re: AP 56" rear leaves? #37288 07/10/02 02:37 AM
might be an odd ball question but couldn't you take the 56" springs and have them re-arched at a spring shop to fit onto the factory placed spring plates and shakle hangers or would it after time have to much strain on the hangers ?????
Re: AP 56" rear leaves? #37289 07/10/02 02:55 AM
Josh Offline OP
Having them arched to fit into stock hangers would do 2 things. One it would probobly give you about 10" of lift. Two, it would defeat the pourpose of having them. The reason to switch to them is so that you can have lots of lift with little arch. This gives you much better flex off road.
Josh
Re: AP 56" rear leaves? #37290 07/10/02 03:00 AM
so basicly it would be good for a show not go
Re: AP 56" rear leaves? #37291 07/10/02 04:10 AM
Adam F Offline
Wont the longer leafs and repositioned spring mounts move your axle 1.5" or so forward, thus giving you more firewall/tire clearance? I thought that was the main advantage of longer leafs.
97 4R, stock, daily driver
Re: AP 56" rear leaves? #37292 07/10/02 04:15 AM
Josh Offline OP
There is no fire wall in the rear chief <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Josh
Re: AP 56" rear leaves? #37293 07/10/02 04:42 AM
Adam F Offline
long day
PHP: 7.4.33 Page Time: 0.009s Queries: 14 (0.006s) Memory: 0.6155 MB (Peak: 0.7121 MB) Data Comp: Off Server Time: 2026-11-01 16:02:59 UTC
