Oil Leak... [was : Oil Pressure!]
#430545
04/06/04 04:22 PM
My truck is losing oil, not fast, but apparently spraying from some place near the oil filter. After wiping it up and watching it a couple of days, I decided to try replacing the oil pressure sender because it seemed to be at the epicenter of the mess. I put the new one in this morning and immediately my oil pressure guage started reading "normal", as in "normal" for other vehicles - not the "low normal" we're used to. Before it warmed up it stayed near the second mark, after that it stayed near the middle of the range. Then I noticed by the end of my 20 minute drive to work it was back to "low normal"... Oh well.
I'm still not sure if that fixed my oil leak, I'll wait a couple of days before deciding on that. Anybody else ever have a leak there?
Scott
ps - surlynkid - Carrol says your hat is on the way
Re: Oil Pressure!
[Re: Scott Broam]
#430546
04/06/04 05:31 PM
ps - surlynkid - Carrol says your hat is on the way <img src="/forums/images/graemlins/lol.gif" alt="" />
4xGeek (Chris) '97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc... No longer stuck in SoCal!!
Re: Oil Pressure!
[Re: Scott Broam]
#430547
04/06/04 05:33 PM
Yeah, I had the sender replaced on my first T by the dealership, because I didn't believe that it always read "low normal." Well, for awhile it read normal but it quickly reverted to the "low normal" we have all grown accustomed to.
1998 Toyota T100 SR5 ExtraCab 4WD
Re: Oil Pressure!
[Re: 4xGeek]
#430548
04/06/04 08:44 PM
ps - surlynkid - Carrol says your hat is on the way <img src="/forums/images/graemlins/lol.gif" alt="" /> but i do not wear hats. i give away my gettel hats.
Scott Landon 1995 T100 - total buildup underway 1988 4Runner (22RE, W56) - new DD 2005 Dodge CTD 4x4 - Tow Beast 1990 Spec Miata 2010 GT3 2013 E92 M3
Re: Oil Pressure!
[Re: Scott Broam]
#430549
04/07/04 01:09 AM
My other vehicle is a jeep. No funny comments now. Anyway the diaphragm inside the oil pressure sending unit broke. This caused oil to weep out thru the back of the electrical connector. Something I was not expecting.
Re: Oil Pressure!
[Re: Scott Broam]
#430550
04/07/04 01:55 AM
A friend of mine had her oil pressure unit give out in her 93 pickup. Just gave way and pumped all the oil out. It ruined the engine before she could shut it off. . Good thing you got it early, if that was the problem.
1997 T-100 4X4 Xcab,Warn Hubs 02 Camry LE 2008 Yaris
Re: Oil Pressure!
[Re: garym]
#430551
04/07/04 10:11 PM
I'm not *sure* that was the problem - there looks to be some more fresh oil in that area today. There is oil on the underside of my alternator, oil filter, and it has dripped on every thing below and behind (oil pan, cross member, steering rack). I think when it is leaking, probably while under power and the pressure is up, it is spraying *up* from somewhere *below*. Any ideas if it is not the sender and my oil filter is on tight? It's not going fast, not noticeable on the dip stick at fill ups, but maybe a half quart by oil change time.
I'm not used to my driveway having oil spots since I traded that Chevy in oh those many years ago...
Re: Oil Pressure!
[Re: Scott Broam]
#430552
04/07/04 10:18 PM
driver's side cam seal??
crank seal??
Re: Oil Pressure!
[Re: surlynkid]
#430553
04/08/04 03:35 PM
Have you checked the oil filter itself? On rare occasions I have seen the rubber seal partially detach when it is screwed on too tight or if there is debris or some of the seal from the last filter left on there. The seams could be leaking on it too. Just a guess. You also should have an oil cooler with a line to it but that is further back.
Re: Oil Pressure!
[Re: garym]
#430554
04/08/04 04:18 PM
I noticed the leak before the last oil change and it continued after that. I think it has slowed with the replacement of the sender, but I'm pretty sure it has not stopped (new oil where I cleaned up).
First thing I checked was the filter. About a year ago, I had quite an oil leak at the filter - I could only get it to stop with an extra half turn of the filter. I use Toyota filters almost exclusively, with an occasional Purolator thrown in - I think the one I was using at that time was a Toy filter. Anyone else find that the Toyota filters need a little more tightening than those with a solid rubber gasket?
Where I'm finding the oil is forward of the oil cooler, but I'll take another look at that.
Cam seals were replaced at timing belt replacement about 10K ago.
Crank seals, I dunno...
