Re: Clicking In The front End ? #430609 04/06/04 11:25 PM
And For Note The Clicking Im Geeting Is Only Or I Can Only Here It When Im In Frist Gear Or Under 15mph Going In A Stright Line Not Turning ?
Thanks
Nick
Re: Clicking In The front End ? #430610 04/06/04 11:49 PM
92Pickup Offline
I was getting a clicking sound coming from my passenger side front, actually it was kinda loud, but i only heard it when i was turning to the left or everynow and then when i went over some bumps. When i got home i took the wheel off and discovered that the top pin in the brake callaper that holds the pads in had sliped out and was rubbing up against the wheel. Might be completey different then what your hearing but it's worth looking at.
Re: Clicking In The front End ? [Re: 92Pickup] #430611 04/07/04 12:55 AM
will do i just did my brakes so this could be ill check cuz i didnt notice it till after i did the brake job ill be off at 5 ill post if that is it
Re: Clicking In The front End ? #430612 04/07/04 01:03 AM
OOP'S Offline
It is the pads bouncing off the rotors until they warm up!~~ Does not happen as much with OEM pads. You might need to buy some new anti-rattle spring thingies from the dealer. Nothing really to worry about!!!!! <img src="/forums/images/graemlins/smile.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Clicking In The front End ? [Re: OOP'S] #430613 04/07/04 04:21 AM
Yes cuz now i notice it when i tap on the brake pedal lightly it not a click its a taping (lol)
Thanks OOPS
And All Other Peps That chimned in
Nick
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6026 MB (Peak: 0.6830 MB) Data Comp: Off Server Time: 2026-06-20 17:31:27 UTC
