Superwinch manual hubs with a 1994 SR #430615 04/06/04 06:15 PM
merikgvr4&sr Offline OP
Good morning, I switched my 89 Monty to an Aisin hub and would like to install the Superwinch in my Pop's SR.
Would this hub work with the Gen II's? Anything to look out for? Thanks in advance for any help.
89 Malljero 4dr V6
94 Monstero SR (sold)
91 GVR4 turbo powa too many mods
83 300TD turbo diesel powa
Re: Superwinch manual hubs with a 1994 SR [Re: merikgvr4&sr] #430616 04/06/04 07:17 PM
montyjo Offline
I put the Superwinch hubs on my 95 about 6 months ago. I've had no problems at all. Got mine through Summit Racing, lowest price I found.
1995 Montero SR
SuperWinch Hubs, 31x10.5 BFG A/T'S
Re: Superwinch manual hubs with a 1994 SR [Re: montyjo] #430617 04/06/04 07:45 PM
Thx MontyJo. Any mpg improvement? I know I read somewhere here that there will be problems when shifted to 4hi when the hubs are unlocked. Is this true?
I am not worried when my Pops drives the SR as he understands when I tell him something to watch out for. It is my other family members that borrows the SR on their long trips so I wanted to make sure that it will not be a problem when shifting to 4 hi with the hubs unlocked.
Thanks again for your input MJ.
89 Malljero 4dr V6
Re: Superwinch manual hubs with a 1994 SR [Re: merikgvr4&sr] #430618 04/07/04 03:14 AM
sparkem Offline
With the hubs unlocked, 4 wheel drive will not work.
Re: Superwinch manual hubs with a 1994 SR [Re: sparkem] #430619 04/07/04 03:56 AM
Charlie Belew Offline
If you run your truck in 4wd...center diff unlocked...hubs unlocked, your transfer case is gonna send 70% power to the rear (good) & 30% to the front (bad!). If center diff locked, transfer case will send 50% front & 50% rear. Still bad!
It will feel like your tranny is slipping as your only getting 70% or 50% power to move the rig depending on the situation.
I've also heard this can be bad for your transfer case.
None
Re: Superwinch manual hubs with a 1994 SR [Re: merikgvr4&sr] #430620 04/07/04 04:06 AM
BobShaw Offline
You should not shift into 4HI while moving with either the manual or automatic hubs. You can with fixed hubs only.
If the hubs are unlocked and you are in 2wd, the front shaft and axles are not rotating. IF you shift into 4wd on the fly, it will be a dynamic load on the front drive train and you will break something.
Bob Shaw
superchief87@adelphia.net
Re: Superwinch manual hubs with a 1994 SR [Re: BobShaw] #430621 04/07/04 07:36 AM
Got it, thanks for the confirmation. Will tell my Pops about it and see if he still wants to install the manual hubs.
Thanks also for everyone else's input in this matter.
89 Malljero 4dr V6
Re: Superwinch manual hubs with a 1994 SR [Re: BobShaw] #430622 04/07/04 03:10 PM
stony-man Offline
Bob Shaw
Wait, what? I thought you could ONLY shift into 4-hi if you HAD auto hubs...I have autohubs, and I've never had any trouble...maybe I'm misunderstanding you...oh, and btw, I'm in Tuscarawas County...not too far from you smile
Re: Superwinch manual hubs with a 1994 SR [Re: stony-man] #430623 04/07/04 03:13 PM
I was a little confused by his post too. But since he's the great Bob Shaw I didn't question it.
I'm wondering if he is talking about the Active Trac system or just referencing the Gen 1 4wd system?
Re: Superwinch manual hubs with a 1994 SR [Re: Charlie Belew] #430624 04/07/04 03:27 PM
He must be talking GenI...
Call me stupid (wouldn't be the first), but who is "the great Bob Shaw?" Could Stony and I be so lucky as to have a guru so close to us? (It frustrates me to no end that all you other guys are no where near us. <img src="/forums/images/graemlins/frown.gif" alt="" />)
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6422 MB (Peak: 0.7639 MB) Data Comp: Off Server Time: 2026-06-17 04:03:41 UTC
