speedometer stopped working #431432 04/08/04 03:25 AM
Sturdy Offline OP
Has anybody had any trouble with their speedometers going out? I checked under the truck and it looks like everything going into the tranny is OK. Any other thoughts or experience? It is a 93 Trooper RS.
Mike
Mike
04 Tundra
01 Discovery
93 Trooper RS- Lifted, Locked- SOLD
93 Trooper RS- Teras, Lifted, Locked- ROLLED&SOLD
87 Trooper-Lift-SOLD
90 Trooper-Teras and lifts-SOLD
96 Trooper-Graveyard
Re: speedometer stopped working [Re: Sturdy] #431433 04/08/04 03:40 AM
mlclark Offline
Isuzu Moderator
The cable broke. A new one is going to cost you about $50, I believe.
Unscrew the end of the cable from the tail housing and pull on the middle part. Most likely, it will come apart.
Michael
Re: speedometer stopped working [Re: Sturdy] #431434 04/08/04 03:52 PM
my speedo went bad not long after the truck was purchased...the spring bound up and that was that...but this is not something that happens often. Check the cable.
Re: speedometer stopped working [Re: Sturdy] #431435 04/09/04 02:24 AM
hunterdan Offline
On really cold days, my gears in my speedometer stick for the first 2 miles or so making a really horrible grinding noise, the speedometer doesnt work too well while this is happening and no matter how hard you hit the dash, it doesnt go away, until you come to a compete stop 2 times (the first stop is up the road, and the second one is on the other side of the mountain and by then the heater is usually blowing out semi warm air). This all happens even tho all the connections are tight.
Dan
92 Rodeo, 3.1 TB crank, custom bumpstop spacers, DOR shackles, Flipped ball joints, D44 Rear, 4.56s and new magnaflow cat and dynomax ultraflow muffler Since been replaced by a 2 door Explorer on 31's shackles, cranked torsion bars and full exhaust
Re: speedometer stopped working [Re: Sturdy] #431436 04/11/04 09:11 PM
Sturdy Offline OP
Did some research into this. There is no speedometer cable for the 93 Trooper. However, there are two vehicle speed sensors. One attaches to the rear of the transmission just like the older cable driven speedos. The other is part of the speedometer assembly in the console. The shop manual provides a procedure to test the sensors. Will let everyone know how those tests turn out in a day or two.
Mike
Mike
04 Tundra
01 Discovery
Re: speedometer stopped working [Re: Sturdy] #431437 04/11/04 09:59 PM
9
94redrodeo Offline
If you have crossed water lately it will be your transfer case speed sensor that went bad
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6092 MB (Peak: 0.6788 MB) Data Comp: Off Server Time: 2026-07-13 14:30:58 UTC
