Intake plenum ? #432453 04/09/04 08:31 PM
Dark_Angel Offline OP
OK, I have my 3.5 tore down. Can someone explain the reasoning for the intake manifold/plenum setup. There are 6 throttle plates inside the plenum that are vacumn activated. Is this basically working like a vacumn secondary on a carb? Is there a drawback to removing them? I noticed that there is a lso alot of carbon buildup on the inside of the plenum, back on the TB and on the plates. It is causing it to stick. Any suggestions?
Thanks,
2000 Trooper 4x4, Auto, TOD pretty much stock at the moment.
2001 Camaro Z28, M6, fully loaded and too many mods to list! AKA Dark Angel
Re: Intake plenum ? [Re: Dark_Angel] #432454 04/09/04 10:22 PM
houlster Offline
Isuzu Moderator
The intake is a dual-runner design. Long runners at low rpm for improved torque, then they switch over to short runners at higher rpm for improved breathing and hp.
Yes. You will loose either torque at low rpm, or hp at high rpm, depending on what runners are "on" with the plates removed.
Thanks,
Clean it out? There's not really anything you can do to prevent it. Carbon build-up is just something all engines have with EGR and PCV system. Not much you can do without disabling these.
--Dan
Re: Intake plenum ? [Re: houlster] #432455 04/09/04 10:43 PM
Thanks, Makes sense to me. I will just clean it and go with it. I thought about making a block-off plate to put between the EGR and the intake, esentially blocking it, but leaving the EGR visual and soleniod to fool the computer. They seem pretty pointless to me and cuase too many problems. Especially since they got rid of them on the '01 and '02 F-bodies from the factory.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5951 MB (Peak: 0.6497 MB) Data Comp: Off Server Time: 2026-06-17 04:17:58 UTC
