Page 1 of 3 1 2 3
Now it wont start #433979 04/12/04 10:42 PM
fpkelly Offline OP
Replaced Distributor cap, rotor button, and TPS. Used an ohmeter to get the TPS and made sure AFM were within spec. The truck turns over but wont fire. Have a code 12 and 22 I think. Any way to further test this/anyone in St. Louis able to help me further? I'll compensate you for your time. I hate this truck and just want to get outside and play.
Re: Now it wont start [Re: fpkelly] #433980 04/12/04 10:49 PM
Now why do you hate this truck? So, assuming that it started before you replaced the dist cap,rotor and tps.?
Do you have your firing order correct?
It's probably your tps, recheck it?
Clear your codes:pull the efi fuse or disconnect the battery.
Love your truck & it will love you! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Now it wont start #433981 04/12/04 10:53 PM
Esquire812 Offline
I think he already tried that approach....you should see the poor things tailpipe! <img src="/forums/images/graemlins/ignore.gif" alt="" /> LOL couldnt help myself...its Monday and Im ME!!
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Now it wont start [Re: Esquire812] #433982 04/12/04 10:56 PM
Yeah, I would like to see that tailpipe!
How bad is it? If you can't fix it throw it away!
<img src="/forums/images/graemlins/shame.gif" alt="" />
Re: Now it wont start #433983 04/12/04 11:10 PM
fpkelly Offline OP
Tailpipe got hacked to make way for the Chevy's flex. It started a long time ago, back in January. Disconnected battery and only got a Code 22, after I tried starting it and only got lots of cranking did the Code 12 appear again.
Re: Now it wont start [Re: fpkelly] #433984 04/12/04 11:36 PM
So,Let me have all the info: it started back in January,
You thought your tps was bad so you replaced it? Is this correct?
Do you have an rpm gauge? If so, try cranking it over and if your rpm gauge doesn't move could be your ignitor!
What did you do to your afm? Adjust it?
How bout all the obviuos: spark, fuel, check your fuses, wires, plugs,( is the rotor turning inside your cap?)
Timing.
Maybe this helped you! Answer my questions please so we can help ya out! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Now it wont start #433985 04/12/04 11:44 PM
fpkelly Offline OP
RPM gauge isnt moving at all. I made a gasket for around the distributor cap since the old one was dry rotted. Maybe its too thick?
Re: Now it wont start [Re: fpkelly] #433986 04/12/04 11:49 PM
Your rpm gauge should move when you are cranking it over. Sounds like an ignitor!
Do you have spark?
Does your cap fit ok?
I would try an ignitor! Before you try an ignitor, check your fuses (all of them) and also see if you have spark, at the plugs & coil! 10-4?
Good Luck! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Now it wont start [Re: Esquire812] #433987 04/13/04 12:16 AM
ScottFW Offline
Confuscious say: Man who make love to exhaust pipe have hot rod! <img src="/forums/images/graemlins/lol.gif" alt="" />
'85 4Runner (mostly stock) <img src="/forums/images/graemlins/kewl.gif" alt="" /> | '94 Miata <img src="/forums/images/graemlins/smile.gif" alt="" /> | '98 Saturn SC2 <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> | '12 Ford Fusion (wife's company car)
Re: Now it wont start #433988 04/13/04 12:55 AM
fpkelly Offline OP
How do I check for spark? I know I did last week when I pulled the ignitor and got shocked into having two heartbeats. I just pulled the gasket I put on and nothing, RPM gauge still sits still.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6316 MB (Peak: 0.7541 MB) Data Comp: Off Server Time: 2026-06-15 10:34:10 UTC
