Page 2 of 3 1 2 3
Re: fuel delivery increase #434258 05/02/04 01:49 AM
Z
ZackaryMac Offline
I was right...that I wasn't right. Heh heh. Every diesel vehicle that I've owned has had the fuel screw turned by someone, either to the point it didn't smoke much at all, or smoked like a train most of the time. The Isuzu manual, the Robert Bently manual for VW, and any Chilton/Haynes manuals I have read all don't give ANY info on how to set up the pump. I realize it takes proper equipment to get it 100%, but you would think that they could tell you something to at least get it in the same ballpark. Oh well. So all I can do is guess. Until this forum, where there are people that have a clue about this stuff, and it's application to the great Isuzu diesels.
Can anyone confirm that JLemonds comments about removing the cap on the side of the pump, and removing the spring and shim, if it applies to my pump on the 223? Or has tried it? I'm always game for improvements. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1994 Chev S10 Ext.Cab with C223 5spd
1991 S10 Sonoma Ext.Cab with C223 5spd - SOLD
Kubota B6100 diesel with accessories
Re: fuel delivery increase [Re: ZackaryMac] #434259 05/04/04 01:42 AM
Jim_Paget Offline
If there is anyone whose answer you can rely on it is Jerry. He taught for Isuzu for a long time and probably knows the most about Isuzu engines of anyone on the board.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: fuel delivery increase [Re: Jim_Paget] #434260 05/05/04 05:20 AM
YES, I followed Jerry's recommend. It is like putting an advance curve kit in a distributor in a gas engine.
My butt dyno didn't measure anything.
pump advance is place to make power gains. Jerry has a effective and safe method, that does not require the dial indicator.
the screw you are talking about, is it large and at top of rear? It that a cover screw?
robt
fuel delivery increase [Re: JesseJames] #434261 09/26/04 01:05 AM
JesseJames Offline OP
Regarding the previous message posted below, I did finally remove the spring inside the cold start advancer on the injection pump and I'll have to say the engine did accelerate better up through first and second gear. Great tip, JLemond!
Right now I'm in the getting ready to replace the clutch setup in my 86 Trooper TD. Anyone have any tips to save some time for this job if I don't have a garage? How do you get to the top two back bolts in the tranny without pulling the motor out?
Jesse
>...on the side of the pump there is a timing advance >mechanisim, it is called a cold start advancer , but has >nothing to do with temp , it is pressure operated, look >down on the side of the pump and you will see a large >round , looking nut with about a 10 -12 mm hex rite in the >center, unscrew this cap and take out the large holding >spring and any shim if any , and then screw the cap back >on , dont pinch the oring and the timing will advance much >smoother and quicker as you go up thru the gears and it >will eliminaate any of the low speed, mid range eng lay >down in 1st and 2 nd gear, over all runs much better.
1986 Isuzu Trooper II TD 5spd 4x4
98 Mercedes E300 TDi
Re: fuel delivery increase [Re: JesseJames] #434262 10/01/04 03:21 AM
Z
ZackaryMac Offline
I just tried the plunger-spring removal thing today, but didn't feel any difference either. As Jerry pointed out, it certainly would be more noticeable with a sticking pump, rather than a proper-working pump. Fuel timing increase should make a bit of difference, though. Which is what I'm going to do, when I get enough time (better be soon <img src="/forums/images/graemlins/kewl.gif" alt="" /> timing belt is long overdue).
Re: fuel delivery increase [Re: JLEMOND] #434263 01/31/07 03:37 PM
V
Viking_t Offline
Hi All,
Here is one of the pump off my old C223-T engine. I can't seem to find the cap you described at all for cold start
left side
right side [Linked Image]
Pump number [Linked Image]
Re: fuel delivery increase [Re: Viking_t] #434264 02/01/07 12:42 AM
JLEMOND Offline
THIS PUMP DOESNT USE ONE OF THE COLD START DEVICES , IT IS NORMALLY MOUNTED RIGHT UNDER THE TACH SENDING, UNIT , THIS PUMP IS MORE LIKE THE PUMPS THAT WAS USED ON THE EARLY IMARK ENGS , AND AS ZACHERY MENTIONED IF THE ADVANCER IS WORKING CORRECTLY YOU WONT REALLY GAIN ANYHTING FROM TAKING IT OFF THE PUMP , THE PROBLEM WAS A LOT OF THEM TENDED TO STICK AND WOULD CAUSE A PART THROTTLE BOG ON A COLD ENG , OTHER THAN THAT THEY DID FINE , AND TRYIGN TO FIND PARTS FOR THE ADVANCER AND THE PUMP IN GENRALL IS BECOMING MORE AND MORE DIFFICULT, JERRY
Re: fuel delivery increase [Re: JLEMOND] #434265 02/01/07 02:47 AM
A
acy76 Offline
I wonder if the intended market determines whether the cold start device is present - as he is from Australia, it's likely not needed. My Japan-sourced 4JB1-T does not have one, either, although I wish it did for the Minnesota winters (not sure if it's of the same design, though).
1988 Isuzu Trooper LS
2.8l Isuzu 4JB1-TC intercooled turbo diesel
www.dieseltrooper.blogspot.com
Re: fuel delivery increase [Re: JLEMOND] #434266 02/01/07 07:47 AM
V
Viking_t Offline
Thanks Jerry for the info. By the way there isn't much of these engines left at where I live either, looking for part is almost impossible as well. There are quite a few 2.8L and 3.1L around though
Acy76: I just went under my truck that has in imported engine from Japanse and there isn't one in there either.
By the way, I am going to send this pump over to Canada for someone but it seems a bit too much for the postage fee. Which company did you use when you got your bonnet from NL?
Trong
Re: fuel delivery increase [Re: Viking_t] #434267 02/02/07 05:14 AM
A
acy76 Offline
Hi Trong -- I went through All 4x4 Parts for the intercooler scoop.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.009s) Memory: 0.6392 MB (Peak: 0.7651 MB) Data Comp: Off Server Time: 2026-07-15 04:12:32 UTC
