Page 1 of 3 1 2 3
Warn Winch M8000 mounting instructions #37955 07/17/02 07:14 PM
Leo Offline OP
I bought a winch <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" /> but it did not come with instructions on how to mount it to my ARB bumper. Anybody got any installation manual lying around?
Thanks.
2000 - Tundra, V8 2WD Access Cab
Re: Warn Winch M8000 mounting instructions #37956 07/17/02 07:20 PM
anthony1 Offline
yeah!
First...bring it to my house.
Second...help me mount it on my truck... <img border="0" alt="[Hillbilly]" title="" src="graemlins/notooth.gif" /> <img border="0" alt="[Hillbilly]" title="" src="graemlins/notooth.gif" /> <img border="0" alt="[Hillbilly]" title="" src="graemlins/notooth.gif" />
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: Warn Winch M8000 mounting instructions #37957 07/17/02 07:31 PM
Ishikawa Offline
Ummm...4 bolts on bottom....two to hold roller on front of bumper...red cable to positive battery connection...black cable to negative battery connection...mount solenoid box wherever is accessible to you....Turn it on...pull yourself out of hole.
Need more help, let me know. <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Re: Warn Winch M8000 mounting instructions #37958 07/17/02 07:32 PM
moomba Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Leo:
<strong>I bought a winch <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" /> but it did not come with instructions on how to mount it to my ARB bumper. Anybody got any installation manual lying around? </strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">If I can find mine, you can borrow it. It should be pretty self-explanatory though. I mounted my winch without looking at the instructions.
85 4Rnr SR5 - 35" Dick Cepek, Warn M8000, 364k miles
My superbike - 04 Aprilia RSV1000R
My BMW 8-series
Re: Warn Winch M8000 mounting instructions #37959 07/17/02 08:07 PM
jx94148 Offline
By the picture on your website, I see the bumper is already on the truck. Guess what, it has to come off to get the winch inside. Once its off hopefully the holes in the bumper line up with the 4 threaded holes on the bottom of the winch, then its just 4 bolts that hold it in place with lock washers.
<small>[ 17 July 2002, 03:11 PM: Message edited by: jx94148 ]</small>
'87 4Runner. '83 Honda XL250R. No mods on either.
Re: Warn Winch M8000 mounting instructions #37960 07/17/02 08:43 PM
Red_Chili Offline
Toyota Section Staffer
And the fairlead attaches with two of those 4 winch bolts. The cable feeds from the 'bottom' of the winch, which will now be facing forward with the cable coming off the low side of the drum I seem to recall. You can rotate the winch clutch cover to put the engage lever in a more convenient place as you wish, just remove the 10 (allen?) bolts and rotate it where you want. Really straightforward.
The solenoid attaches to the top of the bumper or wherever you want. You did get a non-'i' winch, didn't you?
<small>[ 17 July 2002, 03:44 PM: Message edited by: Bill_Morgan ]</small>
-Bill
Re: Warn Winch M8000 mounting instructions #37961 07/17/02 08:58 PM
Leo Offline OP
Thank you guys for all your replies. Looks pretty straightforward. I just need an extra pair of hands to help me carry the heavy ARB bumper and winch.
Re: Warn Winch M8000 mounting instructions #37962 07/17/02 08:59 PM
Leo Offline OP
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Bill_Morgan:
<strong>
The solenoid attaches to the top of the bumper or wherever you want. You did get a non-'i' winch, didn't you?</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Yep it's a non-"i" winch.
Re: Warn Winch M8000 mounting instructions #37963 07/17/02 10:13 PM
Leo, I just finished an M8000 installation into my ARB Bumper on my 85 4Runner....
Contrary to the instructions and previous reply, you DO NOT have to remove the bumper...
I have all the instructions... The winch instructions is used for the winch wiring, but the ARB bumper instructions have the winch mounting instructions. But it's fairly straight forward...
1. Mount the roller fairlead... Remove the C clips from the two vertical rollers. Hold up to bull bar and mark the holes to drill through the roller fairlead bracket using the bottom two holes. Then drill 1/2" (in about 3 stages, starting 1/4" and then go bigger drill up to 1/2". Keep checking alignment so that the bracket is against top and still centered and the holes line up... Don't bolt up yet. Just test fit.
2. Remove all the allen head screw/bolts on the winch right (drivers side) cover and rotate the cover two holes clockwise. This will rotate the free spool lever so that it is from the 12-1 oclock to about the 3-4 oclock position. Retighten all the allen head screw/bolts.
3. Lift or bench press the winch up through the bottom (you'll have just about 1/8 - 1/4 clearance and have to work at it a little...). Once you have it clear of the bottom lip, you can rest the winch against the bottom lip and not have to hold it as hard. Then get a couple bolts through the front bumper face into the winch mounting holes. The winch bottom holes are in these sliding pieces that fit into the bottom. They slide a little to allow for some play in mounting hole offsets... They want to fall out while lifting and holding the winch up... You might have to remove the allen set screw for the lever to get the winch in. Then just put it back.
3. Get the front bolts in to hold the winch and hold the roller fairlead in. The ARB parts contain two long bolts and lock nuts and washers to remount the two vertical rollers.
4. Wire up the electrical. Mount the solenoid box with the ARB bracket and parts. Then route the solenoid wires to the winch. There is an F1, F2, A, and small wire winch/solenoid ground. Then a long black winch/battery neg, and long positive cable. The F1 from solenoid wire (red I think) goes to F1 post on winch. The wire and post should be labled... Just match them up. F2 (black I think) goes to F2 post. F1 and F2 are the two in the same vertical plane. A post is off to the side.
5. Test the connection. Attach the pos/neg battery/winch connections, make sure small solenoid ground is grounded to winch, and insert controls and test....
Regards,
Tracy Hanson
Re: Warn Winch M8000 mounting instructions #37964 07/18/02 02:10 AM
Leo Offline OP
I looked at my bumper and there is no way I can mount the winch without removing it. I wish it was that easy Tracy. I will have to find time and an extra pair of hands to get this mounted.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6366 MB (Peak: 0.7616 MB) Data Comp: Off Server Time: 2026-11-02 07:42:17 UTC
