Re: 33" tires on IFS along with rubbing (pics) [Re: Paddler] #436377 04/22/04 08:57 PM
kobyhud Offline
Hey now Jeff that isnt true.
You have personally seen a 95 rodeo with 33X12.5s with only a suspension lift. However, I did some pretty good trimming as you well know.
Mine had 33s, now it doesnt have any tires on it. but that is another story smile.
Backspacing is the key though.
I was willing to trim bumper, and fender. I got rid of the frame rub through the rims.
95 Rodeo LS, Auto, SAS, , 60 front, 14 bolt rear. 5.13 r&p, Hydro-Assist, teras..
http://www.pieceofhud.com/gallery
Re: 33" tires on IFS along with rubbing (pics) [Re: Jeff Mason] #436378 04/23/04 05:28 AM
it looks cool, but you'll lose that piece very quickly <img src="/forums/images/graemlins/shiner.gif" alt="" />
You'll need this, too:
and a couple of these:
er, i mean these:
Re: 33" tires on IFS along with rubbing (pics) #436379 04/23/04 01:44 PM
jgalt Offline
NICE
Where, pray-tell, would one acquire such protuberances??
Oh, and do they come in bling-bling?? <img src="/forums/images/graemlins/lol.gif" alt="" />
Jim - ZU'tah Wheeler
'96 Rodeo LS 4x with 3.2L SOHC V6 (6VD1-V) & MUA5
Beyond that <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: 33" tires on IFS along with rubbing (pics) [Re: jgalt] #436380 04/23/04 03:42 PM
L
Landmonster Offline
Those look to be Bushwacker fender flares. Believe it or not, they carry products for our Isuzus. Why can't others follow suit?
JC-Whitney has those in their inventory. Summit carries them, but I don't know if they have some for Isuzus.
Re: 33" tires on IFS along with rubbing (pics) [Re: Landmonster] #436381 04/24/04 08:49 AM
well, let's see here: Ford is disappointed when they only sell 800,000 F series pickups in a year.
Isuzu would need a change of underwear if they sold 20,000 troopers.
I think that sums it up.
Re: 33" tires on IFS along with rubbing (pics) [Re: Jonesy] #436382 04/25/04 11:15 PM
Hi Steve, I'm new on this forum and I noticed your wheels. I have a 2002 Rodeo Sport with 245/70 16" wheels. Today I was looking around for chrome wheels that would fit. I checked American Racing and I'm not sure if it's the same one your have on your Rodeo, but they look the same. Do you know if American Racing makes them to fit the Rodeo Sport to fit mine without changing tires?
Jan
Re: 33" tires on IFS along with rubbing (pics) #436383 04/25/04 11:49 PM
trav Offline
japa-
just do a search here and you will find your back spacing, and your lug pattern. I can't remember what it is right off hand, but it is pretty common and you should be able to find just about any wheel you want to fit...
trav
1998 Isuzu Rodeo -- slightly modified.
Re: 33" tires on IFS along with rubbing (pics) #436384 04/26/04 03:52 AM
Jonesy Offline OP
Jan
Yeah, you can get the American Racing Bajas. You would just get them in a 16x7 or a 16x8. I went for the ProComp Extreme Alloys because the holes are bigger then the AR ones. I do recommend that if you intend to go with larger tires later on you wait on rims until you need a new set of tires and get a combo in the 15" rim size, say a 31x10.5 on a 15x8" wheel. If you decide against that then all you need are 6lug on 5.5 bolt pattern. As far as I know they only come in one offest/backspacing dependent on the size.
Hope that helps.
Steve
'97 Rodeo
3.2L V6
DOR 3" lift, 3"BL, DOR Boulder Bars, Tera-Low's, 33x10.5,Surco Safari Rack, Cobra CB, Rancho 9000's....andnNow with Half-Doors for the summer
Re: 33" tires on IFS along with rubbing (pics) [Re: Jonesy] #436385 04/27/04 01:44 AM
Trav and Steve,
Thanks for the info. I'll do a search and I'll also keep in mind about waiting until I need tires.
Thanks again,
Jan
Re: 33" tires on IFS along with rubbing (pics) #436386 04/29/04 05:46 PM
JOEDIRT Offline
I have been smoking crack but with enough cutting 33-10.50's will fit on a sus lifted rodeo without a BL. Take out the frnder well liner, ground down the flange in the back of the wheel well, Cut the fender back 2" all the way around as well as the bumper and the front valence, then undercoat the whole fender well to keep it from rusting. I am also running 15X8 with 3.75 backspacing. I have 31's but have run 33's and they didn't rub. <img src="/forums/images/graemlins/cheers.gif" alt="" />
97 TJ SE, intake, baja wheels, 31" mudders
Stripped down to a rollin gas can.
PHP: 7.4.33 Page Time: 0.018s Queries: 16 (0.014s) Memory: 0.6339 MB (Peak: 0.7583 MB) Data Comp: Off Server Time: 2026-11-17 11:04:33 UTC
