Body or suspension Lift? #439736 04/22/04 06:09 PM
G
GMJK86SR5 Offline OP
Should I buy the spacer for my 86ifs front suspension, or go with a body lift to get a bit more clearence for my 31 inch tires.
Re: Body or suspension Lift? [Re: GMJK86SR5] #439737 04/22/04 06:17 PM
4Crawler Offline
Should not need either to fit 31s unless you are running very wide or low backspaced wheels. But either would give you additional height and clearance.
Tire fitment information.
Re: Body or suspension Lift? [Re: 4Crawler] #439738 04/22/04 06:44 PM
anthony1 Offline
Dido Roger.
Those things come stock with 31" option.
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: Body or suspension Lift? [Re: GMJK86SR5] #439739 04/22/04 10:30 PM
BeaterToyota Offline
Like already said, you shouldn't need anything for 31"s. I have 32"s with no lift and no clearance problems. However, if you are really set on a lift, either elripster's spacers or Roger's 1" body lift should work just fine.
Jason
'88 Toyota, flatbed junker, Inchworm dual cases, spooled rear.
Re: Body or suspension Lift? [Re: GMJK86SR5] #439740 04/23/04 03:46 AM
If you're sagging at all or you just want a little lift just do blocks shackles or AAL's and crank your torsion bars a little. I wouldn't want to hassle with a body lift plus I really don't like em.
Re: Body or suspension Lift? #439741 04/23/04 12:34 PM
DRTDEVL Offline
Body lifts don't look bad if they are done right...
Re: Body or suspension Lift? [Re: DRTDEVL] #439742 04/23/04 01:59 PM
Dok Offline
I agree 110%:
'87 4-Runner--DD/wheeler, 4.3 swap coming soon
'89 Supra--E85 powered 2jz NA-T Swap, 533rwhp 497ft-lbs
'89 Festiva, turboed BP swap powered by megasquirt
Re: Body or suspension Lift? [Re: Dok] #439743 04/24/04 03:43 AM
DRTDEVL and DOK your 4Runners look sweet! I have a stock 87' black 4Runner I am going to spruce up this summer. Nice. I hope it turns out as well. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Body or suspension Lift? #439744 04/24/04 03:54 AM
Rauch_Off_Road Offline
What are AAL's.
Oh and I did a 2.5in block lift in the back and was amazed at the look, clearance, ease of instalation and oddly the truck seemed to handle better. The next lift will be a 2in body before I start looking at the suspension. Changing the suspension geometry can be sweet if you know hwat you are doing and exactly what you want but I say start cheep and easy then work you r way up to more complicated and fun things. IMHO <img src="/forums/images/graemlins/cheers.gif" alt="" />
(aka suprathepeg, aka Sean)
Re: Body or suspension Lift? [Re: Rauch_Off_Road] #439745 04/24/04 04:11 PM
4Crawler Offline
AAL = Add A Leaf
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6390 MB (Peak: 0.7618 MB) Data Comp: Off Server Time: 2026-11-16 08:55:56 UTC
