Re: Tire size with 5.38's.... or 307 Case [Re: sweater] #439767 04/23/04 12:31 AM
Pyro4117 Offline
went to 5.13's
Where did you track those down? I remember a post here about them being for the overseas diesel models...
Thanks,
Jay
1991 Trooper - DEAD! 2.8 V6, 5 spd, 4WD, HD clutch, 2.25" exhaust, EPROM Chip, KC/Hella, Aisin hubs, Rancho 9000X's, Panasonic/Infinity/Alpine
My Pics
Re: Tire size with 5.38's.... or 307 Case [Re: Pyro4117] #439768 04/23/04 12:40 AM
strawmyers Offline
Isuzu Moderator
You are probably thinking of this post.
I think you are getting your hopes up on this one. Mike has D44's front and rear.... so there is no need to 'track down' special gear sets. Its going to be a lot bigger issue for someone still running the front 10 bolt. Sorry to break your gentle spirit <img src="/forums/images/graemlins/baby.gif" alt="" />
Sean Strawmyer
Re: Tire size with 5.38's.... or 307 Case [Re: strawmyers] #439769 04/23/04 01:20 AM
sweater Offline
Crap. Sorry about that.
When I start thinking 37" and 38" tires, I do not stay focused on Isuzu IFS running those. In fact, were I to move up to those sizes (and the weight of them) I'd most definitely be running 60's or a 14-bolt rear at least. I could just see snapping shafts left and right with that much rubber spinning around...
Re: Tire size with 5.38's.... or 307 Case [Re: strawmyers] #439770 04/23/04 01:50 AM
Pyro4117 Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> Sarcasm duly noted... <img src="/forums/images/graemlins/smile.gif" alt="" />
Probably wouldn't be able to swing ($$$) a set even if I could find them. It would foster a sense of Cosmic Completeness or <insert favorite pyscho-mystical terminology here> something if some Isuzoid somewhere could actually latch onto one of these 'unobtainium' supposed factory gearsets...
[/fantasy world]
Jay
My Pics
Re: Tire size with 5.38's.... or 307 Case [Re: Pyro4117] #439771 04/24/04 03:16 AM
Roadends Offline
Since Feb. I've had the 5.38's in my pick up (stock 4.55/31's). With the 33'3 it feels like a new engine.
I have 167,000+ miles on it and can sustain 65-70 mph on grades (I'll be running up Hwy 50 early May, Randii's neck of the woods <img src="/forums/images/graemlins/coolg.gif" alt="" />, I'll get a true test then <img src="/forums/images/graemlins/baby.gif" alt="" />).
Haven't seen much of a difference with gas milage <img src="/forums/images/graemlins/kewl.gif" alt="" />. My last fill up was calculated at about 19mpg. That's not taking in consideration of tire size/gearing change over stock. Straight freeway I think I can get well over 200 miles on my 14 gal tank. <img src="/forums/images/graemlins/smile.gif" alt="" />
I'm real satisfied with the 5.38/33's combo.
Kim
'99 2wd Rodeo LS, '90 4x4 Isuzu Pick up
Re: Tire size with 5.38's.... or 307 Case [Re: Roadends] #439772 04/24/04 08:00 AM
for the record, with the 2.8 and auto trans, I wouldn't want to run 33's with 5.38 gears. I've got 4.77's and 33" tires and even that puts engine RPM a wee bit higher than I'd like to run all the time.
I think 4.56 with 33's puts the engine in a much happier RPM range on-road - the problem at that point is horsepower, not gearing <img src="/forums/images/graemlins/kewl.gif" alt="" />
please note that I know nothing about the transmission gear ratios in manual trans, or 2.6l equipped trucks <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Tire size with 5.38's.... or 307 Case [Re: TrooperXS] #439773 04/28/04 04:48 AM
90amigo Offline
I was wondering what size tire to run with 5.38 gears i might buy a set since they are going out of production. What would be the best size if i was running the truck as a daily driver
Here is some info
At mph - Speedo says mph
30 - 34
45 - 49
55 - 61
65 - 72
75 - 83 @ 3600 rpm
Yes my gas milage sucks.
90 Amigo,Front 10 bolt with powertrax locker,Rear Dana 44 with Detroit Locker at 5:38.1 R&Ps,Pro Comp MT's 33x12.5 on 15x8 black Rockcrawlers,with a 3" suspension lift.Pro Comp steering Stabilizer.Warn M8000 winch in a ARB bullbar.
Re: Tire size with 5.38's.... or 307 Case [Re: 90amigo] #439774 04/28/04 05:38 AM
strawmyers Offline
Isuzu Moderator
Would be mind giving the number that "sucks" is equal to? I never did get that update from you <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
Sean Strawmyer
Re: Tire size with 5.38's.... or 307 Case [Re: strawmyers] #439775 05/01/04 02:39 AM
90amigo Offline
[/quote]Would be mind giving the number that "sucks" is equal to? I never did get that update from you <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" /> [/quote]
I will go for a ride to daytona bch again and this time write it down. <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6374 MB (Peak: 0.7605 MB) Data Comp: Off Server Time: 2026-11-18 11:51:48 UTC
