Needing to replace A/C compressor #440454 04/24/04 05:40 AM
L
LaCalavera Offline OP
My a/c has not been working since the end of last summer but I put off fixing it over the winter since I was not using it. Now that it is beginning to get warm I really need to get the cold air blowing again. I had the system tested not too long ago and was informed the compressor did have a leak. I have a '91 22re motor running the old R12 refrigerant. I know I have some options in how to solve this problem by either converting to R134a or rebuilding/replacing the current comp with the R12. My question is, would it be easier to rebuild my current compressor and convert to 134, or buy a new one? If I do decide to go the route of buying a new or reman. one, where would be a good place to look w/a reasonable price? Any suggestions would be appreciated. Thanks!
White '91 22RE 4x4 Single Cab
Post deleted by little_joe [Re: LaCalavera] #440455 04/24/04 06:21 AM
Re: Needing to replace A/C compressor #440456 04/24/04 06:41 AM
L
Thanks for the link to the thread and advice theif! Where would you recommend looking for a new or reman. compressor at a reasonable price? And where did you get the Freeze 12 and Duracool?? I went onto the Freeze 12 site but they dont have any dealers in Tx. Dont really want to order online if I can find either two products in a local store. Thanks a bunch for the help!!!
Re: Needing to replace A/C compressor [Re: LaCalavera] #440457 04/25/04 05:47 AM
5spd Offline
Check your local auto parts joints ie: auotzone, pepboys ect for that a/c pump. I can get em all day long out here in the local dismantlers yard for under $30 and all are in perfect condition.
Re: Needing to replace A/C compressor [Re: LaCalavera] #440458 04/25/04 07:56 AM
kewlynx Offline
Was given some R12 by some folks who are leaving the state; PM me your mailing address.
**ubi apis- ibi salus**
Re: Needing to replace A/C compressor [Re: LaCalavera] #440459 04/25/04 09:47 AM
aka HOT SHOT,,,,,or R12R,,,some day someone on this board will say the same,,,,,,,134 sucks,,,no btu value.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6073 MB (Peak: 0.6767 MB) Data Comp: Off Server Time: 2026-06-10 01:33:25 UTC
