Wrong Fluid in x-fer case #440683 04/24/04 11:57 PM
JohnW Offline OP
I changed all my fluids this weekend. Imagine my surprise when I popped the drain plug off the transfer case(not TOD) and saw red ATF flowing out. <img src="/forums/images/graemlins/angry.gif" alt="" /> I say surprise because I did not have time this winter and paid Merchants to replace fluids last time. The ATF was in there for approx. 24K. I plan drain and refill again next week to make sure I got it all out. Having had the wrong fluid in there for so long what kind of problems am I now facing???
Other than the inevitable run around with Merchants <img src="/forums/images/graemlins/evil.gif" alt="" />
2002 Trooper S 5spd, cone filter, Ranchos, Modified for 2WL
Re: Wrong Fluid in x-fer case [Re: JohnW] #440684 04/25/04 12:40 AM
lttlbddy Offline
Of the choice between finding ATF or 90# gear oil in a t-case, I would much rather have the ATF.
You may be okay but definetely go to this Merchants and get something in writing that they screwed up and that they should be liable for any damage or premature failure of this t-case.
Doubt they will do this but worth a try.
Steve G
Re: Wrong Fluid in x-fer case [Re: JohnW] #440685 04/25/04 06:12 AM
This seems common. I had gear oil in mine for a while. It is funny, the fill plugs on my truck have "Engine Oil" stamped on it.
Re: Wrong Fluid in x-fer case [Re: JohnW] #440686 04/25/04 11:11 AM
John- I wouldn't sweat it. Modern ATF is not much more than a 20wt motor oil with some red dye & slightly different additive pkg. If your xfer case normally specs 5w-30 motor oil, you'll be fine. I'd do a couple drain/refill cycles on it anyway.
G/luck
Joel
Re: Wrong Fluid in x-fer case #440687 04/25/04 03:44 PM
JohnW Offline OP
Spoke to Isuzu tech and he seems to think that there will be no problems. Yes the fluid is thinner, but it was only in there durring the winter. Plus there were virtually no metal shavings on the drain plug.
So it looks like I will be OK
Re: Wrong Fluid in x-fer case [Re: JohnW] #440688 04/25/04 09:54 PM
bob large Offline
If my schematic is rite, and you too have a TOD Tcase. There is a small overflow hole between the transfer case and transmission. So putting TC oil in the TC would probably be a bad idea. I think they where right on when they put transmission fluid in it. That is if you have a TOD T case.
Steve C
Re: Wrong Fluid in x-fer case [Re: bob large] #440689 04/25/04 10:05 PM
lttlbddy Offline
Original post says "not TOD".
Steve G
Re: Wrong Fluid in x-fer case [Re: lttlbddy] #440690 04/25/04 10:33 PM
bob large Offline
My bad for not re reading. Sorry <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Steve C
Re: Wrong Fluid in x-fer case [Re: JohnW] #440691 04/25/04 11:22 PM
JLEMOND Offline
Hi john you should have absolutely no problem with the atf , in the trans or the transfer , seeing as how you have a 5spd no tod either , the only thing you wany to watch is the the tranny is not overfilled or the trans fer case , when it runs out the fill hole cold that is it , atf grows as it gets hotter and it could dribble out the breathers , only reason isuzu didn,t like atf it has very little noise deadning quality, but high temp capability and good lubricating quality and it will keep the trans clean , atf has a high content of detergent in it , unless you are towing a heavy trailer a long time and really workin gthe trans you will, be fine Jerry
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6238 MB (Peak: 0.7230 MB) Data Comp: Off Server Time: 2026-06-07 08:01:47 UTC
