new lower control arm bushings #440694 04/25/04 12:24 AM
hunterp Offline OP
im finally putting the lift into my pig but i need to replace my control arm bushings.
they are completely unsalvagable obviously
i went to the parts store and they quoted me on 81 bucks a piece.
bs. right?
i was wondering if anyone fabs up the bushings with the sleeve, maybe in acrylic?
i cant bear to go to the dealership and have them jack me ,like they did on the cam bolts.
anyone?
85 4runner/duals/detroits f&r/5.29s/winch/stuff
Re: new lower control arm bushings [Re: hunterp] #440695 04/25/04 12:44 AM
hunterp Offline OP
i checked out some daystars for like 35 bucks but they require that you reuse the sleeve.
is this wise, considering i will most likely be melting/beating the seized bushing off the sleeve?
Re: new lower control arm bushings [Re: hunterp] #440696 04/25/04 02:31 AM
solarcrew Offline
<img src="/forums/images/graemlins/nana.gif" alt="" />Man,you are in for pure hell replacing those bushings!Go ahead and buy new cam bolts from the dealer.Don't waste time heating and beating on the old bolts.Find a sawzall and cut the bolt on each side of the sleeve.When you get both sleeves out,cut or burn all the old bushing off.Then you might be lucky enough to soak them in some lubricant and drive whats left of the old bolt out.I couldn't find any replacement sleeves anywhere except the ones that came with the toyo bushings.I was able to reuse one of my sleeves but had to make the other one out of a peice of pipe.By the way,I've got a complete upper and lower set of daystars unopened.You can have'em for $25 and that includes shipping!Good luck! <img src="/forums/images/graemlins/cheers.gif" alt="" />
87'4runner-22re,5spd
Re: new lower control arm bushings [Re: solarcrew] #440697 04/25/04 05:48 AM
hunterp Offline OP
nah brah i already got the cam bolts.
nice 80 bucks dropped at the stealership..love it!
give me your email, we'll talk business.
Re: new lower control arm bushings [Re: hunterp] #440698 04/25/04 08:10 AM
Jeff the marmot Offline
I don't know what you guys are talkin' about, but just in case this helps you with a custom solution... I had www.spidertrax.com machine some sleeves to press-fit onto rear lower control link rubber bushings. They sell it as a product now, including the bushings. Link here and here. They're most likely a different size bushing than whatever you have, but it might be a possibility. These are hard rubber but still might be too soft for use in the front since they're rubber and intended to flex some. I'm not sure.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: new lower control arm bushings [Re: Jeff the marmot] #440699 04/25/04 04:57 PM
solarcrew Offline
<img src="/forums/images/graemlins/smile.gif" alt="" />Hunter,you got mail. later,doug
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6088 MB (Peak: 0.6791 MB) Data Comp: Off Server Time: 2026-10-26 16:49:04 UTC
