2000 Air filter question #440849 04/25/04 04:44 PM
I bought a K&N filter off of ebay. All it is is the element itself, no hard plastic.
The filter that is in there now is a paper filter in a non removable plastic shell.
K&N said the dealer should be able to supply the plastic part, but the deal doesn't list it in their catalog.
Did I just get the wrong filter from ebay, or is something missing?
Re: 2000 Air filter question #440850 04/25/04 06:14 PM
This seems to be an ongoing issue with K&N's off of ebay. As this happened not long ago to another person on the board. They didnt recieve the plastic part either.
To see if the filter is the right one just check it against your old one.
Get a hold of the seller and ask for the rest of the filter.(plastic thingy)
Re: 2000 Air filter question #440851 04/25/04 08:23 PM
The thing I don't understand is why doesn't the dealer show this part?
Re: 2000 Air filter question #440852 04/27/04 07:12 PM
JSharp Offline
I doubt anyone will keep this part around since it comes with the filter and isn't something you'd need separately. I'd call K&N directly and see if they will sell you one...
2000 4Runner SR-5, 4X4, 5 Speed, Toyota locker.
Dunlop R/T's, cheap mudflaps, remote oil filter, Deckplate, K & N filter.
My 4Runner
Re: 2000 Air filter question [Re: JSharp] #440853 04/27/04 07:23 PM
jataga Offline
is there anyway you can use a dremel or some type of cutting tool to remove the plastic holder from the stock filter? All mine does is just lay right beside the filter...it doesn't "lock" onto it in any way.
Be sure to do a throttle body cleaning at least every 7500-10000 miles b/c the oil from the filter will get on your MAF sensor and cause your engine light to come on and crap like that.
99 Limited 4Runner 4WD
ARB front Bumper Kennesaw rear bumper
WARN 9500 Winch
Hella 4000s
Re: 2000 Air filter question [Re: JSharp] #440854 04/28/04 02:16 PM
The parts store said it's a dealer item only.
Re: 2000 Air filter question [Re: jataga] #440855 04/28/04 02:19 PM
The plastic on this one wraps around the paper part of the element, instead of being behind it.
Thanks for the link.
Re: 2000 Air filter question #440856 04/28/04 10:12 PM
JSharp Offline
My K&N came with a plastic spacer since it's thinner than the stock filter or the aftermarket paper variety. That part is only used with a K&N...
My 4Runner
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6115 MB (Peak: 0.6918 MB) Data Comp: Off Server Time: 2026-10-21 20:42:24 UTC
