02 Troop Suspension #440905 04/25/04 06:16 PM
SleepO Offline OP
I've been off this post for a while, but as is true to many of you, I added another Troop to my '91; an '02. It is a low miles "Limited." Unfortunately, the thing seems to bottom out when I go over speed bumps. Any reasons/solutions would be appreciated. Don't think I'll be taking it to Brown's Camp, west of Portland, Oregon real soon, but would like a solid ride.
Thanks
Love my '91 and '02 Troopers, yet still old and in the way. Stock can be fun too!
Re: 02 Troop Suspension [Re: SleepO] #440906 04/25/04 08:00 PM
W
Wareagle Offline
I bet your rear axle is resting on the bu,p stops. I know my '01. Old Man Emu progressive spings will help a bunch. Also, look at new rear shocks. No reason to do anything in the front.
Re: 02 Troop Suspension [Re: Wareagle] #440907 04/25/04 10:20 PM
bob large Offline
Ya, I looked at some new troops at a dealer awhile back, and they where just like my 2000. They only have about 1.5" of clearance between the rear axel and the rubber bump stops. From what I can make of it, itÆs supposed to be that way.
The idea is the rubber bump stop is really soft so when youÆre pulling a trailer or really weighting it down the car actually sits on the bump stops and they act almost as a second spring rate. While also stabilizing the vehicle while turning. But the rubber is not so hard that youÆre supposed to feel it when it makes contact during road driving. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
I have quite a bit of lift (about 4ö in back) and have 2ö bump stop spacers to limit up travel. It has about 2ö of clearance between my axel and the bump stop. I notice it hitting occasionally when I really hit a big pot hole on the road at speed. But other than that itÆs fine. So I would suggest getting a set of 912 or 119 OME springs for the back and bring the front up an inch or so to match. That should give you about 2 to 2.5ö of clearance between the axel and bump stop. So as to make contact while street driving unlikely. A new set of high quality shocks will also help the ride. <img src="/forums/images/graemlins/kewl.gif" alt="" />
<img src="/forums/images/graemlins/patriot.gif" alt="" /> darlington-offroad <img src="/forums/images/graemlins/patriot.gif" alt="" />
Steve C
Re: 02 Troop Suspension [Re: SleepO] #440908 04/27/04 02:36 AM
JohnW Offline
Another option to firm up the rear end would be to install air helper springs. they fit right inside the coils and you can get them for less than $75
2002 Trooper S 5spd, cone filter, Ranchos, Modified for 2WL
Re: 02 Troop Suspension [Re: SleepO] #440909 04/27/04 10:37 PM
There are a lot of speed bumps to get into my neighborhood.
I solved the bottoming out by installing Tokico TrekMaster R/T shocks.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6083 MB (Peak: 0.6742 MB) Data Comp: Off Server Time: 2026-11-02 04:01:44 UTC
