Looking for LOCKERS???????????????
#442103
04/28/04 03:46 AM
Found them! A friend of mine here in Korea I met thru one of out sportage clubs has one of the biggest Sportage clubs here in S. Korea. He got me in contact with a person here in Kunsan, by the AF base I am going to set up a meeting with the guy here Hopefully this weekend or the next. I will do my best getting them to the states. The lockers are made by track finder. More info soon.
In midst of building.
Re: Looking for LOCKERS???????????????
[Re: mattnsteph]
#442104
04/28/04 04:15 AM
Kia Moderator
<img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
......as long as they make it to the land of Oz as well!
Front/rear/both( <img src="/forums/images/graemlins/smile.gif" alt="" />)?
[Re: mattnsteph]
#442105
04/28/04 04:22 AM
from my knowlege they are both front and rear. I will have more info on the product itself after the meeting with them. Hopefully this weekend! <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: mattnsteph]
#442106
04/28/04 06:48 AM
extremely good news, too bad i just cut everything off!
95 Sportage w/welded and 5.89 geared dana 44's on 38.5" TSL's.- SADLY SOLD CURRENTLY - 2000 sportage, 5.38 gears, welded diffs, 35" tires, 5.5" lift http://www.cardomain.com/ride/341410
[Re: Dave Scott]
#442107
04/28/04 12:00 PM
Kia Moderator
extremely good news, too bad i just cut everything off! &^^$%#&#%())%&&^%$&***^%$&^@!!!, Dave, you will have to get another one so you can do side-by-side testing <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: mattnsteph]
#442108
04/28/04 12:03 PM
Kia Moderator
Other bits on the wish list:
5.3 or higher R/P's, Lower ratio gears for transfer case. (~2.5:1)
[Re: mattnsteph]
#442109
04/28/04 05:28 PM
keep the wish lists coming when we meet, I want to ask him everything i can possibly ask him for parts.
[Re: mattnsteph]
#442110
04/28/04 05:57 PM
ball joint spacers
diff drop kits
second the lo t-case gears
[Re: Dave Scott]
#442111
04/28/04 09:37 PM
bigger and stronger steering knuckles ... longer struts ... quick disconnect sway bars .. longer brake lines .. stronger master cylinder/booster .. differential and t-case guards .. solution for the right rear shock being dented from the panhard rod mount ..(trimming it a bit is still not enough .. the rear end still drops lower and hits it ..)
[Re: mattnsteph]
#442112
04/29/04 12:18 AM
See if has or knows about getting headers for the Sportage.
