Freeing frozen tie rod end
#444082
05/02/04 10:05 PM
I've been under my CJ-5 for the better part of the morning trying to adjust the tie rod ( I need more toe in) and the passenger side tie rod end just will not budge. It seems that the driver's side is free. I've used PB Blaster and tapped on the tie rod with a ball peen hammer. I've been trying to turn the tie rod with a 14 inch pipe wrench. I'm affraid of putting too much torque on the tie rod thinking that I might pull the tie rod end apart. Any suggestions?
Re: Freeing frozen tie rod end
[Re: 80CJ]
#444083
05/03/04 12:10 AM
get a really hot tourch and heat that nut up then give it a tap, I have been there before with my jeep, somthing so easy is always suck a pain, good luck Mud
[Re: Mudlover27]
#444084
05/03/04 12:39 AM
Good plan with the heat, but also if you get it to move freely remove it and antisieze it.
Also if you break the end with the pipe wrench, it was shot anyway.
SD
[Re: superdawg]
#444085
05/03/04 02:16 AM
Thanks a lot guys. The heat really worked. Just a propane torch but it did the job.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5992 MB (Peak: 0.6545 MB) Data Comp: Off Server Time: 2026-10-24 02:34:26 UTCValid HTML 5 and Valid CSS
