Help w/ Hella 550 Install #444109 05/03/04 12:29 AM
Deron Offline OP
I'm working on installing Hella 550's on my '00 4Runner but I'm pretty much electronically incompetent. The main directions seem fairly straight forward but they have a new type of switch so they added an insert on how to wire up the new switch except that it seems to contradict the main directions and I can't see how to tie it all in. Has anyone installed Hella 550's recently with this new switch? If so can you explain it in a way I can understand? Hopefully one of ya'll can help. Any help is appreciated.
2000 4Runner, OME 882 front coils w/ firm shocks, 891 rear coils w/ firm shocks, Sonoran Steel adjustable rear panhard bar, ARB Prado bullbar, Warn 9,000lb. winch, Amsteel synthetic winch line, Hella Lights, 265/75R16 BFG All Terrains
Re: Help w/ Hella 550 Install [Re: Deron] #444110 05/03/04 06:31 PM
aowRS Offline
Deron,
When I installed my 4000s, I referenced the Hella instructions, but used a Toyota fog light switch to match the one already in my dash.
The lights either ground through their mounting bolt, or have a separate wire for grounding. I used on of the many 10 or 12mm bolts available behind the front bumper - make sure you get a good ground.
You'll have a power wire going from the battery to the Hella relay, a 'signal' wire going from a powered circuit to the relay, a wire leading from the switch to the relay, and a wire going from the relay to the lights. If I remember correctly. The switch may also wish to have a ground if it is illuminated.
The signal wire needs to be tapped into a circuit that is powered in order for the relay to send power to the lights. I believe I pulled from the "aux" fuse.
Hope that helps.
Andreas
2001 4Runner SR5 4WD, Dorado Gold, 303,000+ miles
2014 Audi A4, Monsoon Gray
1995 Porsche 993, Polar Silver
Re: Help w/ Hella 550 Install [Re: aowRS] #444111 05/04/04 01:17 AM
adam Offline
iirc that relay needs to be grounded - least it is on the 550s I set back up last weekend.
That'd leave 3 posts on it unless it's a 5 post relay. Then one wire would come in from the battery to the relay. This should be a gauge thicker than the rest of them and fused.
Another - probably doubled up, 2 wires into a single blade in other words - would run out to the lights.
The 4th should run in from the switch.
At the switch, 1 wire goes to ground. A second is that one going out to the relay and the third comes in from the circuit you tap (I used the parking lights).
~Adam
Re: Help w/ Hella 550 Install [Re: adam] #444112 05/09/04 07:16 AM
if you look on the bottom of the relay and it has numbers like 35,,,87,,,87a or 87c or so 36,,,,its just a good old bosch relay or a bosch copy,,,,,,,I can tell you how to wire it any way you want,,,,but I`m tired and had a few beers and dont feel like diging out the schematics right now,,,its late ,,,,reply tomarrow if you want,,,
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5973 MB (Peak: 0.6583 MB) Data Comp: Off Server Time: 2026-06-07 04:45:48 UTC
