Slip yoke plugged??
#444662
05/03/04 06:54 PM
I'm still trying to find the source of my driveshaft vibrations. This weekend I took off the rear driveshaft from the center bearing to the differential. I noticed the slip yoke is air locked. There is no slop but it feels like a shock absorber when you push against it. The grease causes it to seal and the air can't get around it. I cleaned it out as best I could but I think it should have some sort of weep hole to allow the excess grease and air to come out. I couldn't find one and checked the front driveshaft and didn't see one on there either. Is there supposed to be a hole and mine is just rusted shut?
By the way I don't think it's the cause of my vibrations but that's another post. It's been driving me nuts and it's getting worse. I'm almost to the point of letting whatever it is break so I can find it.
Thanks!
97 T100 4x4 SR5 Extra cab Automatic 3.4L engine
Re: Slip yoke plugged??
[Re: Shedman]
#444663
05/03/04 07:56 PM
Toyota Moderator
[Re: Shedman]
#444664
05/03/04 09:16 PM
I believe mine weeps out around a plug in the end of the shaft nearest the differential.
1997 T 100 4X4 ExtraCab 5 speed, White Worthless factory bedliner 265/75/16 Firestone Destination A/Ts Aisin Manual Hubs 90k miles
[Re: Perpetrator]
#444665
05/04/04 01:08 AM
...and mine doesn't 'cept for the little bit on the slip itself. I remember the first service specs I read specified that the slip didn't take much grease even though it would accept more - 2-3 pumps tops. Sounds like you just got it so slam full that you've created a suction effect.
~Adam  96 T100: D44, lockers and stuff
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6009 MB (Peak: 0.6565 MB) Data Comp: Off Server Time: 2026-06-07 04:19:17 UTCValid HTML 5 and Valid CSS
