4x4 Hub swap #444767 05/03/04 09:30 PM
Hey guys i'm doing some mods to a 93 runner, it has the orig automatic hubs on it and i want to try to get some better gas mileage. If i swap them over to a pair of Warn manual locks will this help me any??? Thanks for the help. I am trying to drive the truck to work and with gas prices going all over the place i need a cheaper route, any other gas saving ideas, also please advise. Much appreciated.
Re: 4x4 Hub swap #444768 05/03/04 10:16 PM
wont help gas milage
Re: 4x4 Hub swap #444769 05/03/04 10:33 PM
little_joe Offline
Former Admin
It will help with your gas mileage, however it's likely to be so slight you may not notice unless you track it closely. Manual hubs are a good swap anyway, less mechanical drag, less wear on CV boots, and they are a direct swap for your ADD flanges (you do not have automatic hubs).
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: 4x4 Hub swap [Re: little_joe] #444770 05/04/04 02:42 AM
well yes add eats up some fuel,,,,what year did they start putting those in,,,,??he said automatic hubs, not add, if so my bad
Re: 4x4 Hub swap #444771 05/04/04 03:06 AM
OOP'S Offline
Do your self a favor and stay away from Warn hubs or for that matter any aftermarket hubs. Get some used Asisn Toyota hubs, for IFS they are a dime a dozen. One thing make sure you get the cone washers with them, I do not know for sure but I have heard (hearsay) that the cone washers run about $2.00 apiece from Toyota, Marlin may have them cheaper!!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: 4x4 Hub swap [Re: OOP'S] #444772 05/04/04 06:51 AM
toy283 Offline
More importantly, I've never run across a dealer that has a dozen of them in stock. I always end up buying two here, three there, etc. As of late, I make a habit of buying a couple every time I'm there whether I need them or not. They just go in a baggie in my parts drawer until I need one.
Dave
'84 X-Cab supercharged 283 V8, SM420, dual cases, etc.
'85 4Runner
Re: 4x4 Hub swap #444773 05/04/04 12:31 PM
A
averkam Offline
The best way to get better mileage is to slow down. Drive 5 mph slower will get you probably 3 mpg better.
2000 Ext Cab SR5 4WD 2.7L 5-speed.
Re: 4x4 Hub swap [Re: OOP'S] #444774 05/04/04 01:50 PM
little_joe Offline
Former Admin
The ADD flanges also use the cone washers, so no need to source them (unless you lose them during removal).
PHP: 7.4.33 Page Time: 4.396s Queries: 15 (4.392s) Memory: 0.6145 MB (Peak: 0.7125 MB) Data Comp: Off Server Time: 2026-10-24 05:25:09 UTC
