Difference between Landcruiser and mini-Truck rear third? #444838 05/03/04 11:43 PM
Spacetrucking Offline OP
Well, didn't research thorougly enough and looks like I am stuck with a rear third for a Landcruiser. Has 4.9 : 1 with a True-Trac, got it on ebay. Seller didn't have all the specs and I bouced it off my mechanic who OK'ed it from the photos. What is the difference between a Landcruiser diff and a mini-truck one?
'86 SR-5 Extra-cab 4 x 4, 2" BL, 33 x 12.5 x 15R M/T on 15 x 8 rockcrawlers ( 3 3/4" BS ), 22RE 5 sp , 4.88's Detroit True-Trac front, V6 open rear, 24 mm Sway-Away + Rancho 5000's, removed sway bar, no-rust south US bed, Ramsey 8000 winch
Re: Difference between Landcruiser and mini-Truck rear third? [Re: Spacetrucking] #444839 05/04/04 01:31 AM
taconut Offline
The land cruiser diff has a 9.5" ring gear and is offset to the passenger side. The mini rear diff has an 8" ring gear and I think it is centered.
Kevin
1989 FJ62
Re: Difference between Landcruiser and mini-Truck rear third? [Re: taconut] #444840 05/04/04 03:25 PM
Thanks for educating me. It's in the for sale scetion here. Super shape by the way. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Difference between Landcruiser and mini-Truck rear third? [Re: Spacetrucking] #444841 05/06/04 12:56 AM
taconut Offline
Don't think I didn't consider it. Is the gearing actually 4.9:1 (haven't heard of that ratio) or is it 4.88:1? If only you had a front to match then we may be on to something. Just don't tell the wifey. <img src="/forums/images/graemlins/wink.gif" alt="" />
Kevin
1989 FJ62
Re: Difference between Landcruiser and mini-Truck rear third? [Re: taconut] #444842 05/07/04 06:11 PM
Double checked it, 49 on ring gear and 10 on pinion. There is a gear maker in my complex , went over and asked him if there were other factors. He confirmed that the gear count is what makes the ratio, so 4.9 : 1 it is. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Difference between Landcruiser and mini-Truck rear third? [Re: Spacetrucking] #444843 05/11/04 07:15 PM
Just got the third back from my mechanic. 12 mounting bolt holes, 12 ring gear bolts, did some research and 9.5" is the right diameter for Lancruiser. What style cruiser does this fit? For sale BTW, made a crate for it. Ready to go. PM for pictures .
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6069 MB (Peak: 0.6762 MB) Data Comp: Off Server Time: 2026-06-13 10:51:44 UTC
