3.5L service - parts to order #447250 05/07/04 10:41 PM
davemtb Offline OP
Just bought a '96 SR w/84k. I am going to change the timing belt, water pump, updated intake plenum, plugs & wires. I've done numerous searches of this Mitsu parts of this site and gleaned the part numbers listed below. I ordered a CD manual for the truck off ebay, but would like to go ahead and get the parts ordered so I can start the work as soon as the manual gets here. Take a look and let me know if I've missed anything.
Do I need any gaskets for the timing cover?
Does anyone have the Mitsubishi part numbers for the timing belt and water pump? Napa seems high, I'd like to check their prices against the stealers.
Parts List
LOWER PLENUM:
MD335940 - Induction Control Valve Assembly
MD300483 - Intake Manifold Plenum Gasket
MD307582 - Induction Control Valve Gasket, Secondary
MD307583 - Induction Control Valve Gasket, Primary
MD184662 - Throttle Body Gasket
MD149764 - EGR Pipe Gasket
PLUGS & WIRES
MD311208 - Spark Plug Cable Set
MD361067 - Spark Plug
TIMING BELT & WATER PUMP
NBH250253 - Napa Camshaft belt - $114
NWP559310 - Napa New Water Pump - $179
Dave Smith
'96 SR - 31x10.5 Tires
"Facts are meaningless. You could use facts to prove anything that's even remotely true!" Homer Simpson
Re: 3.5L service - parts to order [Re: davemtb] #447251 05/08/04 10:00 AM
You can change the timing cover gaskets while you are at it.
Good Luck
Frankie
Re: 3.5L service - parts to order [Re: davemtb] #447252 05/08/04 01:54 PM
hmmm, can't remember if the valve guide seals were fixxed on the 86's but maybe this post will prompt one of the 'guru's here to remind us.
Great aquisition btw smile I think the 95 and 96 SR's are the epitomy of 4x4's. The 95 get's you the slightly over one inch lift from the factory and the 96 gets you the handy dandy split bench rear sear smile Hope you like your 96 as much as I like my 95 smile
seer
Re: 3.5L service - parts to order [Re: davemtb] #447253 05/08/04 08:49 PM
For 1996 3.5DOHC, the info (from Olympia Mitsubishi) you need for the belt & pump is:
Water Pump
Timing Belt
Parts may show up a couple of times, as it's a shopping cart and it remembers what you have been looking at. Also, give the folks at Olympia Mitsu a call to make 100% sure you are getting the right parts.
Hope this helps,
Cheers <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 3.5L service - parts to order #447254 05/09/04 03:20 AM
davemtb Offline OP
It's a great truck. I picked it up from a car lot in the middle of Kansas. The truck had been there since Jan 2003. There isn't a lot of demand for a "mitsu" in Great Bend Kansas I suppose <img src="/forums/images/graemlins/smile.gif" alt="" /> I can't wait to get out West to try it out on some trails.
Dave
Dave Smith
Re: 3.5L service - parts to order #447255 05/09/04 03:24 AM
davemtb Offline OP
Water Pump
Timing Belt
Hope this helps,
Thanks a lot! The local stealer wants $500+ for the intake plenum. That's as far as I got with them on the phone, didn't bother to ask about anything else. I'll give the guys at Olympia a call Monday.
Dave in KC
Dave Smith
Re: 3.5L service - parts to order [Re: davemtb] #447256 05/09/04 03:34 AM
DaphneD Offline
I would outsource your spark plugs and plug wires. I'm sure your plugs are NGKs. If you're gonna spend a chunk of change on plug wires, I'd recommend going with a set of Magnecors.
Re: 3.5L service - parts to order [Re: davemtb] #447257 05/11/04 07:32 PM
davemtb Offline OP
It was recommended that I also replace the tensioner for the timing belt. Anyone know of problems with the 6G74 3.5l tensioner?
Dave Smith
Re: 3.5L service - parts to order [Re: davemtb] #447258 05/11/04 07:54 PM
I think they'll only give you a problem if you don't replace them. <img src="/forums/images/graemlins/smile.gif" alt="" />
Seriously, it's a preventative measure and I think the key thing to fail is the bearing inside them. There has been prior discussion on replacing this bearing but I don't recall the details. Perhaps a search will bring up the thread or others can chime in on this.
Also, there's a 2nd "tensioning" device down there (at least on the '90 3.0 engine there is). Here's a pic & p/n
Maybe someone w/ a dohc svc manual can chime in on this being also a replacement requirement or not.
Ray
Re: 3.5L service - parts to order [Re: off-roader] #447259 05/11/04 09:09 PM
davemtb Offline OP
Of course. I went ahead and ordered the tensioner for the same reason I ordered the water pump.....peace of mind.
Also, to answer my own original question, the gasket for the timing cover is re-usable. <img src="/forums/images/graemlins/wink.gif" alt="" />
Thanks everyone for the help. I'll post a follow-up when I'm done.
Dave
Dave Smith
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6307 MB (Peak: 0.7409 MB) Data Comp: Off Server Time: 2026-11-17 11:18:36 UTC
