GPS Mounts? #448253 05/10/04 08:00 PM
BallaRat Offline OP
I have the Garmin eTrex and tried their "temporary" sticky pad to mount the unit to the dash with their mounting kit. On a warm day just the sun shining through the windshield pretty much turned the stickum to goo and the GPS just kind of wilted off the dash. Roger Brown said his "permanent" sticky pad lasted about a week with the same effect; he's now mounted something on the rear view mirror bracket, but until I can see that, anyone have any trick ideas for mounting to the dash area...?
Don West
Gettin'Off4x4 Member
'94 Reg Cab, 1" BL, 33 MTs, Detroit f/r, 4.88s, dual Marlins, blah blah woof woof
Re: GPS Mounts? [Re: BallaRat] #448254 05/10/04 08:11 PM
4Crawler Offline
Here's mine (for Garmin StreetPilot-III):
Just a bent piece of sheet metal that fits under the r/v mirror mount, then screwed the base of the GPS mounting bracket to it instead of using the adhesive pad.
Re: GPS Mounts? [Re: 4Crawler] #448255 05/10/04 08:25 PM
BallaRat Offline OP
Hmmmm, kimosabe, me beginning to understand. <img src="/forums/images/graemlins/pfft.gif" alt="" />
Don West
Re: GPS Mounts? [Re: BallaRat] #448256 05/10/04 08:45 PM
Robinhood150 Offline
I have a dash carpet so I bent up a piece of sheetmetal and slid it under the carpet. It's also stuck under there with velcro but the adhesive also melted off, but the dash carpet keeps it in place.
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
Re: GPS Mounts? [Re: Robinhood150] #448257 05/10/04 09:20 PM
4Crawler Offline
W/ GPS in place:
Re: GPS Mounts? [Re: 4Crawler] #448258 05/10/04 09:41 PM
BallaRat Offline OP
Hey Roger...
Does your GPS have the sensor external from the unit itself? I'm questioning whether the eTrex can pick up the bird so mounted; it needs a clear shot to the upper part of the unit.
Don West
Re: GPS Mounts? [Re: BallaRat] #448259 05/10/04 09:46 PM
4Crawler Offline
I run the external antenna from Garmin, it sits on the roof and cable runs in under the sunroof. To run the built-in antenna, I need to have it dash-mounted. In my VW, I have the external antenna mounted w/ a suction cup behind the r/v mirror and the GPS mounted in the center console:
Re: GPS Mounts? [Re: 4Crawler] #448260 05/10/04 10:02 PM
BallaRat Offline OP
Cool; I'll have to see if Garmin has anything external for the eTrex, but I'm thinking not....
Don West
Re: GPS Mounts? [Re: BallaRat] #448261 05/10/04 10:18 PM
4Crawler Offline
Re: GPS Mounts? [Re: BallaRat] #448262 05/10/04 10:41 PM
John Smith Offline
I use a cell phone holder that I found at target to hold my etrex. It is made by samsonite of all people and it uses a suction cup on the windshield and two arms to squeeze the gps and hold it. It works really well for me as it is close enough to the windshield to get a great signal and easy to see also.
/HijackON What is required to display the etrex output realtime to the garmin software on a laptop? I can take a trip and upload my route to the garmin software but can't figure out how to make it track realtime while driving. Is this possible? Perhaps the poor etrex is not high tech enough? My laptop map is much easier to follow than the little screen on the gps. /Hijack off
I can get you a picture of the samsonite cell phone holder if you want me to.
John Smith 79 FJ40
87 StdCab w/22R TLCA# 9074
PHP: 7.4.33 Page Time: 0.020s Queries: 16 (0.016s) Memory: 0.6479 MB (Peak: 0.7682 MB) Data Comp: Off Server Time: 2026-11-18 03:40:12 UTC
