89 trooper 2.6L 4ZE1 into 89 p-up? #449013 05/12/04 03:36 AM
doby/reddevil Offline OP
will this trooper motor swap into a same year p-up 5 spd 2wd.
is the oil pan different? will the p-up tranny work? same clutch?
are the trooper and the p-up 2.6 the same?
any input would be great
89 trooper SAS/SOA v8 on 35s
locked f/r
my site:http://members.fortunecity.com/dobyreddevil
Re: 89 trooper 2.6L 4ZE1 into 89 p-up? [Re: doby/reddevil] #449014 05/13/04 03:09 AM
Kevin Wolford Offline
This doesn't exactly answer your question but I put a 90 somthing PUP engine in my 88 trooper (Got off eBay). You really need a doner engine to swap the wiring harness (swap intakes). The PUP and the Trooper of SOME vintages have slightly different distributors and wiring harnesses. Everything else fit no problem. I have a spare manual wiring harness and PUP distributor if you want.
Good Luck,
Kevin
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5884 MB (Peak: 0.6364 MB) Data Comp: Off Server Time: 2026-11-17 11:24:35 UTC
