Need help picking out a good wiring kit and trailer hitch for my 92 4runner
#449200
05/12/04 06:10 PM
Like it says. I need your guys wisdom on deciding which brand of hitch, class, and wiring to install on my newly purchased 1992 4runner with factory 31" tires. (only 24k miles, but that's another story <img src="/forums/images/graemlins/nana.gif" alt="" /> ) I have found no "T" connector harnesses for this particular vehicle. I know nothing about wiring this stuff up, and the wiring adapters for this model all seem to fall into the "generic fit" category. I don't know what ones are good, and what is crap. Same goes for the hitches. THANKS! Jason
1992 4runner, all stock, just got it. only 24k miles!!!!!!!!
1992 Toy Pickup V-6 Reg Cab 33 BFT AT/ko, 3 lift 230k miles
Re: Need help picking out a good wiring kit and trailer hitch for my 92 4runner
[Re: Jason_dup1]
#449201
05/12/04 06:27 PM
You got a choice, go with a ball on the factory bumper or go with a frame mounted hitch for more towing capacity.
Either one you can do yourself. Just make sure the frame hitch will clear your spare. Any hitch worth considering will be a direct bolt on-no drilling required.
The wiring I would do myself. Most of the hitch places use them little blue clips to attach to your bed wires. With those, a month down the road, things won't work, so buy the proper taillight/trailer light converter and connect it yourself. There, things need to be soldered and shrink-wrapped properly to last.
I prefer 'Hidden Hitch'products.
#449202
05/12/04 06:53 PM
Thanks for the input YODADDY. Anyone have any part#'s or anything for a good wiring kit they've used? I found many universal ones, but am unsure of exactly which one I need. I think I'm going to get the hidden hitch #87020 class III hitch.
[Re: Jason_dup1]
#449203
05/12/04 11:56 PM
try this http://www.jcwhitney.com/webapp/wcs...mp;amp;mediaCode=ZX&appId=616862I think the 90's pickup tail light wiring is the same as the 4runner .....maybe?
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are. It's freedom OF religion not from. 95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
[Re: anthony1]
#449204
05/13/04 03:37 AM
not quite. there is NO t-connector until like 92-93'ish. you have to wire straight into the wires...
leo d. 90 4runner, v6, auto, WCOR CitB kit, marlin duals, arb rear, tt front 4.88, blah, blah, blah... Pres. of TEAM IFS! and GETTING OFF 4WD Club member
[Re: ldivinag]
#449205
05/13/04 05:12 AM
I don't think you need the T connector to use that. All you do is unplug the wire harness going to the tail lights and plug this thing in one side and plug the other side in to the tail light. The wires then goes to the hitch.
[Re: anthony1]
#449206
05/13/04 08:51 AM
problem with 89.5 to like 92-93'ish, is that the wiring harness terminates at the tail light assembly.
the only connectors are hidden behind the body panels.
93 and up had a t-connector somewhere along the bottom of the tailgate. that's where you insert these T's and makes hookups painless...
[Re: ldivinag]
#449207
05/13/04 07:06 PM
Ahhh ic... <img src="/forums/images/graemlins/baby.gif" alt="" /> thanks for not flaming me..... <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> In that case, his only choice is to splice the wires then.
