rear defroster #449656 05/13/04 02:02 PM
justtin00j Offline OP
one of the wires on my rear defroster unconnected itself. i was wondering if i could solder it back to the window and will it work?
Re: rear defroster [Re: justtin00j] #449657 05/13/04 02:41 PM
three of my defrost wires become scratched and didn't do their job anymore. I grabbed a special pen from a local electronics shop that does the same thing as sodering, without the heat. Ran about $10 and made my job easier. Luckily that was before the window was tinted. Good luck
Re: rear defroster [Re: justtin00j] #449658 05/13/04 02:47 PM
litnin Offline
Most auto parts stores sell a repair kit for the defrosters wires. They are actually painted wires and it would not be easy to solder them and make it stick. The kit allows you to repaint them with the conductive material and repair the gap. It comes with instructions...
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: rear defroster [Re: justtin00j] #449659 05/13/04 02:57 PM
jeepfiend Offline
Are you talking about the tab on the window, not just one of the wires? Yes they can be resoldered, but you have to be very careful. The metal on the window is very thin and it easily burns, while the tab is fairly heavy and takes a lot of heat to get the solder on it. I tinned up the tab and then held it against the window with a blunt tip on a soldering iron. I burned the metal on the window a little, but it worked to reattach the connector. It has been working for over two years now with no problems. Be sure to clean everything before you try to do it. I went over the metal on the window and the tab with emery cloth to remove any oxidation so the solder would more easily bond.
It's a race against rust and the Trooper can't go fast enough to win!
Re: rear defroster [Re: jeepfiend] #449660 05/13/04 03:14 PM
yeah it is one of the tabs that came off. I'll try this weekend to reconnect the tab
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6042 MB (Peak: 0.6648 MB) Data Comp: Off Server Time: 2026-11-18 03:44:38 UTC
