22R carb questions (with pics) #449961 05/14/04 02:51 AM
W
whitetoy Offline OP
What the heck is this thing ? I got it off a 22R
when I pulled the fuel pump. It was in-line with
the intake of the fuel pump. Could it be a
non-adjustable regulator, or a second filter ?
Blows air freely from one direction and not quite
so freely in the other direction (direction of fuel flow). No factory markings on it.
Also, here's a pic of the vacuum switch for the
deceleration-fuel-cut system. Very simple device,
but not sure if it is working properly. Supposed to be a closed switch (continuity) with no vacuum
applied (I verified that). Supposed to open when
vacuum applied. I tried to manually apply vacuum
but it wouldn't open. Does this thing require
more vacuum than the diaphrams need to open ?
Rick
1984 4Runner
Re: 22R carb questions (with pics) [Re: whitetoy] #449962 05/14/04 02:55 AM
CJM Offline
first pic is a "aftermarket" fuel filter ... not stock ....
the second pic is of a oil pressure sender ... for the "idiot light" in the dash .
83 Trekker SR5
NEW Trekker forum
Re: 22R carb questions (with pics) [Re: CJM] #449963 05/14/04 06:24 AM
W
whitetoy Offline OP
Thanx for the response.
The second item may look like an oil pressure
sender, but the tubing led to the intake
manifold, so it doesn't make sense for it to
measure oil pressure.
Rick
1984 4Runner
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5918 MB (Peak: 0.6463 MB) Data Comp: Off Server Time: 2026-11-02 19:28:31 UTC
