noisy alternator...time to save $$$?
#451568
05/17/04 11:29 PM
My truck has developed a high pitched noise that sounds like the noise you might hear on your stereo speakers if you didn't have a RF filter. The noise seems to follow the speed of the motor and as best I can tell it's coming from the alternator. It's still putting out 13.8v to the battery at this point but I'm curious what would be causing the sound and how long I should expect it to last now? I should note that I recently replaced the drive belts. Thanks for any clues.
Regards, Indy
Re: noisy alternator...time to save $$$?
[Re: indy]
#451569
05/17/04 11:32 PM
Just for giggles, can you remove the alt. belt, start it up for a few, and see if the noise still persists? That will at least rule out alt/belt.
[Re: Staceman]
#451570
05/17/04 11:44 PM
Yeah,I was thinking I'd try that tonight just to see what happens. BTW I've been reading my FSM and you gotta' drain the what (!) and remove the what (!) to get that sucker out of there?! Those Toyota engineers don't make it too easy on us do they?
Regards, Indy
[Re: indy]
#451571
05/17/04 11:52 PM
Don't know. Got me. I don't have a FSM, but I can loosen an alternator, and pull the belt without doing all that other nonsense. <img src="/forums/images/graemlins/coolg.gif" alt="" />
[Re: Staceman]
#451572
05/18/04 12:03 AM
The belt is easy...but if the unit itself has to be removed it entails draining the radiator and removing the bottom hose. Not too tough, just time consuming.
Regards, indy
Post deleted by little_joe
[Re: indy]
#451573
05/18/04 12:17 AM
#451574
05/18/04 01:25 AM
Well, I tried removing the drive belt from the alt. & PS one at a time to see if the noise changes...no change. I haven't driven my truck in a couple weeks, so maybe I've just forgotten what it's supposed to sound like. Guess I'll put this one in the 'if it aint broke quit messin' with it' file for now and just keep an ear on it.
Regards, Indy
[Re: indy]
#451575
05/18/04 04:34 AM
If you do have to remove the alt, you don't have to drain the coolant. I unbolted my PS pump and kinda twisted/moved it out of the way, and I was able to take tha alt out from the top. I don't have A/C, so I don't know if that would make any difference. Don't think so though. Todd
1986 Pickup extracab longbed "Woody edition" SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD" 94 2wd v6 extracab 04 Outback Wagon- wife's/family car
