Chk Engine Light - O2 Sensor #451584 05/18/04 12:01 AM
RichK Offline OP
I got a check engine light yesterday and checked the code (27). The book says O2 Sensor Malfunction, replace O2 sensor.
I called Toyota, and they want $140 for a new sensor!! Wow, I guess I thought small part = small price.
Anyway, before I drop $140, is there anything else I should check first? Wires? Fuses? Are aftermarket O2 sensors any good?
Oh yeah, I checked my code with the following link:
http://www.off-road.com/toyota/tech/codes/
Another Oh yeah, there is an O2 sensor before and after the CAT. Which one to replace? Both? Hope not.
Thanks,
Rich
1993 4X4 Toyota Pickup XtraCab
22re (ATK Remanufactured)
Re: Chk Engine Light - O2 Sensor [Re: RichK] #451585 05/18/04 12:09 AM
mt_goat Offline
Give these guys a call: http://www.toyota-parts.com/ Tell them you are an internet customer and you will get a good discount.
Is this for your 93? My 93 only has one O2 sensor.
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: Chk Engine Light - O2 Sensor [Re: mt_goat] #451586 05/18/04 02:06 AM
RichK Offline OP
Thanks, I'll give them a call. Anyone had to replace an O2 sensor before on a 90's pickup? Any advice?
Re: Chk Engine Light - O2 Sensor [Re: RichK] #451587 05/18/04 02:14 AM
Go to sparkplugs.com get the Universal Denso....it is $ 49.00 Mine works great....Universal you have to splice the wires.....
Re: Chk Engine Light - O2 Sensor #451588 05/18/04 02:24 AM
RichK Offline OP
I have a California pickup and I believe it has two Oxygen sensors; one before the CAT and after it. Which one should I replace with a code 27?
Thanks,
Rich
Post deleted by little_joe [Re: RichK] #451589 05/18/04 02:51 AM
Re: Chk Engine Light - O2 Sensor #451590 05/18/04 03:49 AM
RichK Offline OP
I know, dumb question: The one BEHIND the cat is the second one FROM the engine?
Thanks...
Post deleted by little_joe [Re: RichK] #451591 05/18/04 07:18 AM
Re: Chk Engine Light - O2 Sensor #451592 05/18/04 04:35 PM
RichK Offline OP
Are they the same part #, or different. I was thinking about getting one and switching it back and forth until the check light went away.
Rich
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6188 MB (Peak: 0.7041 MB) Data Comp: Off Server Time: 2026-06-20 22:48:18 UTC
