80 amp fuseable link blown AGAIN #39629 08/02/02 02:20 PM
jx94148 Offline OP
Any one else have this problem? For the 3rd time the fuseable link that runs everything but the headlights, emergency flashers, and ignition has blown on my truck. This time it happened when I stepped on the brake, that's what did it the first time to, the second time I think it was the heater fan turning on that blew it. I carry one with me because of the previous times it has happened so it works again, for now. I have an electrical problem somewhere that causes this to happen about once a year. I'm just wondering if anyone has any suggestions on where to start tracking down the cause of this stupid crap.
Thanks, Matt
'87 4Runner. '83 Honda XL250R. No mods on either.
Re: 80 amp fuseable link blown AGAIN #39630 08/02/02 03:14 PM
Dandeman Offline
Toyota Moderator
I would examine very carefully all wiring between the fusible link and the downstream fuse panels for damaged insulation and check the back side of fuse panel itself for any damage or foreign objects. Also recheck everything you've added electrically to make sure there are no unfused connections that pull current through the fusible link.
If there was an intermittent short in your brake light circuit, or heater fan for example, it would pop the smaller downstream fuse and not the fusible link.
A short that can pop the fusible link has to be a potential fire concern.
<small>[ 02 August 2002, 10:18 AM: Message edited by: Dandeman ]</small>
PHP: 7.4.33 Page Time: 0.005s Queries: 14 (0.004s) Memory: 0.5870 MB (Peak: 0.6356 MB) Data Comp: Off Server Time: 2026-06-17 11:24:19 UTC
