Page 2 of 3 1 2 3
Re: bud built crossmembers for T100's [Re: surlynkid] #452545 05/21/04 04:33 PM
Brew Offline
Now a 2" notched center support bearing modification to allow a 2" engine and drivetrain lift sounds like a better solution than the extended transmission and transfercase shifters and it just so happens I bought a spare TC shifter when my mechanic began hacking/welding on my original. The engine lift is a no-brainer with my electric radiator fan so my only unknown is whether there would be any issues with the front driveline. I never wanted a huge lift but I really hate how much clearance the crossmember steals. I really like my lift but want my spring mounts to be the only protrusion visible on a side view. Looks like my mechanic is gonna be getting some more use out of his welder. <img src="/forums/images/graemlins/smile.gif" alt="" /> Brew
98 T100 SR5 4x4 3.4L auto, TRD Goodies, Bilsteins, engine/TC skids, 2" body/d.train lifts, F/R ARBs, 4.56 R&Ps, Aisin hubs, 255/85R16 Dunlop Rover RVXTs (street), 16x7 +8mm offset wheels, custom bumpers, Warn M8000, Master-pull synth. line
Re: bud built crossmembers for T100's [Re: Brew] #452546 05/21/04 05:04 PM
surlynkid Offline OP
Here is what you would need to do except you would still need to accomodate the carrier bearing. Erik has a single piece rear CV shaft, so he did not care about a carrier bearing. He only did this to make the CV shaft clear teh crossmember when he added the dual crawler.
Erik's Notched Crossmember
With a full 2" drivetrain lift, you would not want to run at high speeds in 4WD. The driveshaft angle is too steep at the pinion. Since Erik built his own front IFS lift on the T100, he was able to design in a better pinion angle.
Erik's T100 Front Pinion
I would try to figure out how to modify your IFS lift to allow you to rotate the front pinion up like Erik. If you did that, you would be home free.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: bud built crossmembers for T100's [Re: surlynkid] #452547 05/21/04 05:38 PM
Brew Offline
SurlynKid,
I don't have an IFS lift rather I am using a 2" B.Lift so perhaps I will have to leave the 2"/1" as my best alternative. I may just deal with a 2" gain on a "stock" budbuilt and call it cheap versus reengineering a solution my mechanic would have to try to fabricate. <img src="/forums/images/graemlins/baby.gif" alt="" /> Brew
Re: bud built crossmembers for T100's [Re: Brew] #452548 05/21/04 07:03 PM
with no susp lift, your driveshaft angles will be better and may not cause a front driveshaft problem. i bet it will work in your case.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: bud built crossmembers for T100's [Re: surlynkid] #452549 05/21/04 09:50 PM
ErikB Offline
Toyota Moderator
A DT lift should not cause any front driveshaft problems. Most of the 4" lift kits don't change the front pinion angle at all and don't have problems.
The Superlift kit did though (another reason I like the SL kit), and I liked that, so I copied it.
I guess I need to do some updates to my page. <img src="/forums/images/graemlins/sleeping.gif" alt="" /> My 4runner crossmemeber doesn't look like that anymore...
http://home.4x4wire.com/erik
Re: bud built crossmembers for T100's [Re: ErikB] #452550 05/21/04 10:09 PM
4
4xGeek Offline
And a bunch of your links don't work anymore either...<img src="/forums/images/graemlins/nana.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: bud built crossmembers for T100's [Re: ErikB] #452551 05/22/04 03:04 AM
no, it is only bad with a 4" susp lift and a drivetrain lift. even then, it is find a off road speeds. you just would not want to be going fast.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: bud built crossmembers for T100's [Re: surlynkid] #452552 05/22/04 03:58 PM
ErikB Offline
Toyota Moderator
FWIW, I've got no 4wd vibes on my truck w/ the 4" SL + 2"/1" DTL. Not just offroad speeeds, 50-60 MPH in the snow/wet roads in the mountains. Maybe that's because of the good pinon angle...? I do know that the CV in the front driveshaft is near its stock angle limit though.
Re: bud built crossmembers for T100's [Re: ErikB] #452553 05/22/04 05:01 PM
my front cv angle was so extreme that i went and checked rogerb's site for max rpm at different angles. i then kept it that max rpm when wheeling. mine was horrific compared to yours.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: bud built crossmembers for T100's [Re: surlynkid] #452554 05/25/04 12:45 AM
bud r Offline
Thanks for the birthday present Scott! smile
Here are some pics of the first T100 dual case crossmember, both installed and not. Note that this one was bent with an additional 1" of drop for the customer. I forget why tho... <img src="/forums/images/graemlins/frown.gif" alt="" />
Bud R 828-572-1202
98-04 Tacoma, locked, dual cases, ready to go smile
http://www.budbuilt.com
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6475 MB (Peak: 0.7696 MB) Data Comp: Off Server Time: 2026-11-16 08:55:37 UTC
