R154 trans in place of W56... #452677 05/20/04 12:17 AM
Esquire812 Offline OP
So is it possible? The trans is out of an 88' Supra turbo...was wondering if it was similar to the R151 trans that is swappable.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: R154 trans in place of W56... [Re: Esquire812] #452678 05/20/04 12:31 AM
mosk Offline
Darin,
The short answer is, "not easily."
This thread has a more detailed explanation:
http://www.4x4wire.com/forums/showflat.php?Cat=&Board=UBB11&Number=433812
-Jeff
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: R154 trans in place of W56... [Re: mosk] #452679 05/20/04 01:06 AM
Thanks for the link Jeff, exactly the information I needed. Whole reason I asked: There is an R154 local for $150 with 66,000 miles on it. Last night I tore the rear case off of my spare W56 to see if I could find the source of a piece of bearing internals I found under the shifter. Found it! lol Anyways, not like its needed or anything, just all of a sudded took an interest in transmissions etc.
Thanks again.
85' Sillyca 22R-Esq
Re: R154 trans in place of W56... [Re: Esquire812] #452680 05/20/04 02:57 PM
Red_Chili Offline
Toyota Section Staffer
Ya know, I kinda doubt one observation in that thread, that first gear is part of the shaft. Its pressed on. I don't know if it could be pressed off and a new one reliably pressed on though. I also wonder if the R151 tail housing could be swapped to support a transfer case.
Kinda moot though, if you have access to an R151, you probably would just rebuild it and use it.
Darrin, got your PM. Looks like you are getting the tranny bug. Its not hard to work on those babies, much easier than a motor overhaul... <img src="/forums/images/graemlins/coolg.gif" alt="" /> Follow the article tricks and your W56 will be a sweet shifter.
-Bill
Re: R154 trans in place of W56... [Re: Red_Chili] #452681 05/20/04 03:42 PM
Dok Offline
Yoda Man over at BC4x4 swapped the R154 internals into a 151 case for his 7mgte swap, might be worth checkin out:
http://bb.bc4x4.com/showthread.php?...mp;threadid=28289&highlight=r154
'87 4-Runner--DD/wheeler, 4.3 swap coming soon
'89 Supra--E85 powered 2jz NA-T Swap, 533rwhp 497ft-lbs
'89 Festiva, turboed BP swap powered by megasquirt
Re: R154 trans in place of W56... [Re: Dok] #452682 05/20/04 05:42 PM
Red_Chili Offline
Appears to be a R150 case. Very, very similar. You're stuck with either the chain drive transfer case or about a $400 bill for a Marlin adapter though.
-Bill
Re: R154 trans in place of W56... [Re: Red_Chili] #452683 05/21/04 03:44 PM
I'm pretty sure you CAN swap the R151 tail onto an R154....But like you said, if you have an R151 to swap from, why would you bother?....Unless your're trying to run an R-series trans behind a Supra motor....
As to the input shaft, according to Marlin, THEEEE Master, the input and gear ARE machined from one piece... <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: R154 trans in place of W56... [Re: Red_Chili] #452684 05/24/04 04:09 PM
SuperRunner Offline
I don't think they are talking about 1st gear, they are talking about "THE" first gear on the input shaft. It is part of the input shaft, and I believe it has been welded on. The problem with this, is that this gear is different on the R151 and the R154. This gear drives the counter shaft. This caused a hole slew of problems, but still makes it possible. From what I have read, you get a terrible 1st gear because of all this.
It is better to make torque at high rpm than at low rpm, because you can take advtage of gearing.
www.supracharged.com
1994 4runner - SAS, 38 TSL's, Turbo 7MGTE swap, Turbo Tranny
Dual T-case, D44/D60 ront/rear
Re: R154 trans in place of W56... [Re: SuperRunner] #452685 05/24/04 06:34 PM
Red_Chili Offline
Yep, same gear I was referring to. I think its pressed on, because a mechanic friend uses the input shaft sans gear as a clutch tool. Mind you, I doubt my 12 ton press could separate it (there's 'merely' pressed on, then there is REALLY QUITE SINCERELY pressed on). <img src="/forums/images/graemlins/lol.gif" alt="" />
-Bill
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.013s) Memory: 0.6303 MB (Peak: 0.7355 MB) Data Comp: Off Server Time: 2026-11-18 22:34:48 UTC
