Spring Spacers (still a budget lift) #453149 05/21/04 04:07 AM
BTrout Offline OP
Saw a post by Big Blue a while back where he said he prefered Aluminum for lift parts... <img src="/forums/images/graemlins/coolg.gif" alt="" />
So @ work today these fell from the Sky.. yea, that's it, <img src="/forums/images/graemlins/ignore.gif" alt="" /> from the sky...
2" Alum coil spacers, I make Aluminum some days between meetings, training, & safety permits...
I estimated the dementions, so we'll have to see how well they fit.
Installing them & my new KYB's TOMORROW! <img src="/forums/images/graemlins/kewl.gif" alt="" />
'89 Monty LWB: Auto, 3" Budget Lift, 2" Body Lift, 33x11.50 Toyo MT, KYB's, LSD, Superwinch Hubs, Warn X8000i, Rock Sliders, Bumpers & STUFF Fab'd by me
'89 Raider SWB: LSD, 31" Toyo AT's, KYB's
'97 Trooper LS
Re: Spring Spacers (still a budget lift) [Re: BTrout] #453150 05/21/04 04:15 AM
PHIL_ Offline
Fixed your non-working pic for you.
Those spacers look very nice (much more effective that the rubber ones I have). Hope they work as good as they look! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Spring Spacers (still a budget lift) [Re: PHIL_] #453151 05/21/04 04:45 AM
I always wondered if you should coat aluminum before using it anywhere on the body/frame - isn't there something about the steel corroding faster when it's in contact with aluminum or am I remembering it wrong?
Shawn
Re: Spring Spacers (still a budget lift) [Re: PHIL_] #453152 05/21/04 05:02 AM
BTrout Offline OP
Thanks Phil,
Something I did? or was it monty-pics?
Shawn:
I don't know about the electrolisis (sp?) factor. I think I'll just install them & have a look in a few months. Spose I could coat them with some rino-in-a-can...
Anyone else have any thoughts on this?
Lookin @ installin spacers, KYB's & sliders this weekend, and a transmission filter change & pcv valve... during the commercials <img src="/forums/images/graemlins/smile.gif" alt="" />
Happy Trails
Bob
'97 Trooper LS
Re: Spring Spacers (still a budget lift) [Re: BTrout] #453153 05/21/04 03:34 PM
L
Lee N Offline
Yes, aluminum in contact with steel will promote galvanic corrosion. Add a coat of paint between the two surfaces or maybe some herculiner, undercoating, etc. and that should take care of it.
Lee
'94 LS, 3.0 V6, Auto, completely stock
Re: Spring Spacers (still a budget lift) [Re: Lee N] #453154 05/22/04 02:30 PM
BTrout Offline OP
Thanks Lee,
I had the same thoughts after I posted last... <img src="/forums/images/graemlins/confused.gif" alt="" />
These were a real BEAR to install. Took me all day (well... 6 hours anyway) for the two and my new KYB's on the rear. I had to run back to NAPA and buy a cheap set of spring compressors. Then I compressed the coils to about 12" from 16"+ for installation. that was the <img src="/forums/images/graemlins/shocked.gif" alt="" /> scary part. Kept waiting for one of those clamps to break and take my head off <img src="/forums/images/graemlins/notooth.gif" alt="" />
Getting the spring compressors off after installation was somewhat of a chore as well.
They did fit very nice though and 2 more inches of lift <img src="/forums/images/graemlins/kewl.gif" alt="" />
My tires are starting to look a little small... $$$
waz up wit dat <img src="/forums/images/graemlins/smile.gif" alt="" />
'97 Trooper LS
Re: Spring Spacers (still a budget lift) [Re: Lee N] #453155 05/22/04 05:20 PM
Big Blue Offline
true BUT, how many years (dozens, hundreds??) will it take until there is enough corrosion to make a difference in height, or structurial properties.
Kary
1987 Mitsubishi Pajero "Modified"
The other original Mitsu brother
Northwest Trailmaster
Re: Spring Spacers (still a budget lift) [Re: Big Blue] #453156 05/24/04 08:28 PM
TobyB Offline
Depends on where you are.
In the NE, with salt, the aluminum will be eaten away SIGNIFICANTLY in a few years.
Here in the NW, you could probably get away with it indefinately.
Toby
'89 V6 4dr- '4- Doris'
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6246 MB (Peak: 0.7209 MB) Data Comp: Off Server Time: 2026-11-02 05:16:38 UTC
