Need advice - reattaching speed sensor to t-case #453184 05/21/04 05:13 AM
rodeo_chris Offline OP
I'm an idiot and managed to break the clip that holds the speed sensor onto the transfer case.(94 Rodeo, V6, MUA5, speed sensor not cable)
For several months the cable stayed in place on its own. Tuesday it came loose on the interstate, speedo went to 0 and the CE light came on. I reset the CE light and used some duct tape to hold the sensor on there.
Kinda sporatically working now. What are my choices for keeping that thing on there for good? I'm leaning towards some JB Weld on the outer circumference of it unless someone can think of a reason this would interfere with its operation or a better idea. Let me know what you come up with.
-chris
94 Rodeo, 35's, 5.38's, locked F&R, Rocker bar on one side, other side in garage
96 Tacoma, DD, pre-dented
Re: Need advice - reattaching speed sensor to t-case [Re: rodeo_chris] #453185 05/21/04 03:26 PM
Bigpoppax2 Offline
You could get a big flat washer or a steel ring with a break in it(to get it over the cable) and drill some holes in the ring/washer then use some short self tappers to hold it to the t-case.
Of course you'd want to watch your depth on the self tappers. Don't know if I'd want to do anything quite as permanent as JB weld.
Re: Need advice - reattaching speed sensor to t-case [Re: rodeo_chris] #453186 05/21/04 05:53 PM
randii Offline
I'd just replace the clip with the Isuzu-intended piece... is it not available individually?
The speed sensors that I have seen (admittedly all cable drives have a separate piece that retains them... describe what you have on your speed sensor?
Randii
Randy Burleson
4x4Wire Managing Editor Emeritus
Mongrel Isuzu Amigo
Re: Need advice - reattaching speed sensor to t-case [Re: randii] #453187 05/22/04 04:48 AM
Randii
Not sure if it is available separately or not.
The piece that broke off was just a plastic clip. Kinda like the clips in the door jam on the wires that run to the doors. Push down on one side and lift on the other and they usually pop right out. Guess it just got too brittle over the past 10 years.
I'm headed home tomorrow where a proper repair will be attempted. My speedometer has been so far off for so long that I've gotten used to the drive by tach technique.
Thanks guys,
-chris
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.012s) Memory: 0.6031 MB (Peak: 0.6592 MB) Data Comp: Off Server Time: 2026-11-17 11:04:28 UTC
