Tires for a T100 #455137 05/25/04 06:28 PM
IÆm not sure what my T came from the factory with, but when I got it with 48K miles on it, it had 31X10.50Æs. Based on the mileage, IÆm assuming they were the originals. I have subsequently replaced them w/ 31X10.50Æs. Now since IÆm a cheapskate and want to save every measly penny I can, and since the ownerÆs manual indicates both sizes, can I go with a P235/75R15 rather than the 31x10.5R15. What does it do to the performance, mpg, speedometer reading, etc.?
Oh yea, 95% of my driving is highway.
Thanks for any help.
-E
Re: Tires for a T100 #455138 05/25/04 08:31 PM
4
4xGeek Offline
The size you referenced is considerably smaller than 31x10.5... It's only 29x9. Your speedometer & odometer will register higher than actual (plan on about 7-8 over @ 60 mph).
That said, it will actually help your performance in city driving... You'll notice a smidge more grunt in the low end (i.e. - stoplight to stoplight). But you'll lose overall mpg (especially on the highway).
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Tires for a T100 #455139 05/25/04 10:16 PM
T-Rex Offline
If you have 31" now, I assume you probably have a 4x4. If so, I would stick to the 31" as smaller tires will mean higher RPM (more gas) as you do mostly highway driving.
If you want to save a few bucks, try to find a tires that starts with "P" with the same overall diameter of 31" that is more suited for passenger cars. The benefit of such is that the tires most likely is lighter, and narrower than the standard 31x10.5/15. The narrower foot print would mean less rolling resistance. The drawback is that you won't be able to carry the heavy loads your truck is built for, and the sidewall maybe weaker if you take it offroad.
Another cheapie idea is re-treads. The re-tread industry has improved quite a bit over the years. Most trucks and commercial fleet vehicles are all running re-tread tires. They offer similar performance, but will save you about 20% or so in cost. Not a lot, but some savings.
Lastly, you can always look under local classifieds for used tires that are factory take-offs. Many people that buys new trucks may want to upgrade their wheels and tires immediately. Sometimes, you can get a very good price on an almost new set of tires.
02 Tacoma Double Cab TRD Prerunner .. just added 3" lift .. more to come
Re: Tires for a T100 #455140 05/26/04 02:29 AM
garym Offline
Usually the sticker on the driver's side door jamb has the original size tires printed on it.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: Tires for a T100 [Re: garym] #455141 05/28/04 05:04 PM
A
Adam Cramer Offline
I know my truck came from the factory with 31" tires, but the sticker on the door indicates 235's. So the sticker is not correct if you have and 4x4. I don't think any 4x4's came with 235's.
Re: Tires for a T100 [Re: Adam Cramer] #455142 05/28/04 06:10 PM
So that means that the speedometer is off from the start becuase of the tire size change right? So if Im runnin 33's, how far off is my speedometer? (being that it should have been calibrated to the 235's)
Re: Tires for a T100 [Re: Adam Cramer] #455143 05/28/04 06:31 PM
H2O_MAN Offline
My '96 4WD came with 235's. The 31's were optional.
I'm running 31's and my speedo shows about 4 or 5 mph less than actual. I've been running 31's for over 100K and this means my real total odometer reading should be a bit over 200K even though it reads just over 185K.
Re: Tires for a T100 [Re: H2O_MAN] #455144 05/29/04 04:10 AM
adam Offline
31s were a no-option option when we got ours. All the DXs in the area had 31s, sort of a no-charge upgrade on the base model.
~Adam
Re: Tires for a T100 [Re: adam] #455145 05/29/04 05:21 PM
uzombie Offline
I have a set of 5 31's (factory rims) sitting in a shed, looking for a new owner. The spare is the original and still has those little nibs on the tread (as in never used).
If in the PA/NJ area, email me if you want to buy them.
(sorry for the plug)
Anyway, they were 31's with the 95 DX. Speedo was not off (it is now with 33's). <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6238 MB (Peak: 0.7234 MB) Data Comp: Off Server Time: 2026-06-21 00:19:49 UTC
