Codes 25&26 #455406 05/26/04 02:48 AM
N
nader454 Offline OP
I get a code 25&26(o2 lean-O2 rich) at the same time on my 22re. I replaced the o2 sensor to no avail. Clearing the codes shuts it off for a day or so. Wiring harness to sensor looks good. Where else should I look? Thanks.
Re: Codes 25&26 [Re: nader454] #455407 05/26/04 05:44 AM
fire4effect Offline
I used to get this too on my 3.0. Never understood how you could get both codes (lead/rich) at the same time. Since you've changed the O2 sensor, try cleaning the TB and/or airfilter. Not sure why, but this resolved the code for me.
Re: Codes 25&26 [Re: nader454] #455408 05/26/04 09:28 PM
Did you use a Toyota O2 Sensor or a am? See, if you used an am vs. the Toy brand, sometimes the "nipple" isn't long enough to read the flow of gasses going through the pipe!
Also, like Albagtas said: clean your T-body out!
Good Luck! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Codes 25&26 #455409 05/27/04 06:01 AM
N
nader454 Offline OP
Thanks, I'll give it a try. I used a bosch universal sensor.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5964 MB (Peak: 0.6545 MB) Data Comp: Off Server Time: 2026-06-10 06:13:05 UTC
