Jet performance, ECU tunned #455852 05/26/04 10:06 PM
banshee4785 Offline OP
has anyone tryed or know of anyone that has sent their ecu into jet performance where they retune the computer? I am down to a last resort for power other than the headers on the way, so i wanted to know if it makes a diff. It claims for a 15-17hp gain. any input would be appreciated.
thanks
95 4x4 ext cAB t100-
Re: Jet performance, ECU tunned [Re: banshee4785] #455853 05/26/04 10:16 PM
Chris V Offline
Here...
since you refuse to search.
JET Performance chip in T100
1996 T100 SR5, 4" Procomp Stage2,
33x12.5x15 tires
http://members.cardomain.com/chris_t100
Re: Jet performance, ECU tunned [Re: Chris V] #455854 05/27/04 05:10 PM
sorry man, jezzee all i wanted to know if anyone had gotten one since then, i did do a search and read all of the inforamtion. anyways, im gonna combine it with a catback, headers, and my throtal body spacer and mabey my cold air intake, and i think that it will work, i have to try it.
thanks,
ill tell u all how it goes... <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Jet performance, ECU tunned [Re: banshee4785] #455855 05/27/04 06:54 PM
H2O_MAN Offline
banshee, your sig line reads "tundra v-8,trany,leather buckets, and RINO in the works."
<img src="/forums/images/graemlins/confused.gif" alt="" /> Is this V8 in your T100 or do you have a Tundra? Just curious ...
Also, the only chip I have read anything good about is the UniChip.
All of the others seem to be good for lightening your wallet and thats it.
Re: Jet performance, ECU tunned [Re: H2O_MAN] #455856 05/27/04 07:28 PM
T-Rex Offline
Jet Performance overall has a very good reputation, but for our trucks, I doubt you'll see much gain from it. Vehicles that most benefit are sports cars with high reving engine, or any turbo charged gas/diesel as in the full-size Dodge/Ford/GM trucks. For instance, I have an Acura Integra GSR, which has the VTEC engine that redlines at 8100 RPM. For that car, I'm thinking of getting a peformance chip for it, and it should work well.
One of the drawback for out T is that the gain in HP is mostly towards the upper end of the RPM, which means you'll only see it when your engine is above 4000 RPM or so. On my T, my RPM rarely sees beyond 4000 RPM. The other issue is that you would have to use high octane gas to see any potential gain, and that's a good 20 cents per gallon more. Considering how expensive gas are these days, it'll all add up.
But then again, if you have the money for it, it'll be interesting to see what result it'll produce. If it's my money, I would save it for a super charger. Good luck and keep us in the loop.
02 Tacoma Double Cab TRD Prerunner .. just added 3" lift .. more to come
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6065 MB (Peak: 0.6715 MB) Data Comp: Off Server Time: 2026-06-07 08:02:06 UTC
