Tranny final ratio, '93 YJ #456863 05/28/04 11:02 PM
GreggieAtTheBat Offline OP
'93 YJ S, 4 cyl, 5 speed (AX5?)
What is 5th gear ratio? 1:1, or overdrive?
I'm just curious... I know I have 4.10 (or 4.11) diff gears, and seems like I should be pulling more revs at 70, but I could (easily) be mistaken.
Thanks!
1993 YJ S, 2.5L I4, 5spd
30x9.50x15 TAKOs on 15x8 American Racing Rock Crawlers
Re: Tranny final ratio, '93 YJ [Re: GreggieAtTheBat] #456864 05/28/04 11:07 PM
an ax5 has a 5th ratio of .79:1, same as the ax15 iirc.
Re: Tranny final ratio, '93 YJ #456865 05/28/04 11:09 PM
So 4th gear is the 1:1 gear, and 5th is overdrive, 0.79:1. Thanks!
Re: Tranny final ratio, '93 YJ [Re: GreggieAtTheBat] #456866 05/28/04 11:12 PM
JeePete Offline
5th is overdrive but not the same as ax15. ax5 is .85 to 1
Re: Tranny final ratio, '93 YJ [Re: JeePete] #456867 06/02/04 07:18 PM
where did you get your info? every place i look it says .79:1........
Re: Tranny final ratio, '93 YJ #456868 06/02/04 08:02 PM
JeePete Offline
Re: Tranny final ratio, '93 YJ [Re: JeePete] #456869 06/02/04 10:09 PM
Wow, 4.74 reverse ratio, that explains the little reverse peel-out last night when I was hurrying a little bit...
Re: Tranny final ratio, '93 YJ [Re: JeePete] #456870 06/03/04 04:22 PM
i trust the pirate bible more...
http://www.pirate4x4.com/tech/bible/#T
Re: Tranny final ratio, '93 YJ #456871 06/03/04 05:10 PM
JeePete Offline
If it's on the internet It's gotta be true! Right? <img src="/forums/images/graemlins/smile.gif" alt="" /> May be more than one option, I don't know. Either way it's overdrive! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Tranny final ratio, '93 YJ [Re: JeePete] #456872 06/03/04 09:07 PM
true, it is an overdrive and that is what he was asking <img src="/forums/images/graemlins/smile.gif" alt="" />
i personally trust pirate for information like this. they have broken more of them than i will ever even see! the tech info there has never let me down <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6295 MB (Peak: 0.7346 MB) Data Comp: Off Server Time: 2026-11-17 11:25:40 UTC
