Diagram for 91 montero Throttle Position Sensor #457591 05/31/04 06:09 PM
jetcitydude Offline OP
Any one got a diagram for 91 montero Throttle Position Sensor. There are four pins on this TPS. Pins 1-4 on measure 4.4 kohms. Pins 1-3 show .11 ohms to 4.4 Kohms. Pin 2 to pin 1 shows Open to 4.4 kohms and appears to be a switch? Can anyone confirm this? I look a 316 stealth site and this is what is used on the 3.0 stealth. Does anyone know if this is correct for the 91 montero? My ECU just rebuilt is show code 14 for TSP problem. <img src="/forums/images/graemlins/confused.gif" alt="" /> Does anyone have the factory manual for the 91 montero, I have looked for 6 months and can not find one anywhere.(Ebay, Internet, Stealer, Helm Inc) <img src="/forums/images/graemlins/confused.gif" alt="" />
1991 Montero 3.0 V6 Auto 4X4,1986 Fiero 3.8
Re: Diagram for 91 montero Throttle Position Sensor [Re: jetcitydude] #457592 05/31/04 08:00 PM
Vic Lee Offline
This is from the 1990 Mits FSM. It should be the same as yours. I have taken a 1991 apart for spares and so far all of the MPI parts are the came between it and my 1990.
[Note that the last 2 are from a different portion of the MPI section of the FSM.
************ See Post Below* **************
Re: Diagram for 91 montero Throttle Position Sensor [Re: Vic Lee] #457593 06/02/04 06:27 AM
Vic can you repost those pictures or can I try the links?
thanks
Jetcitydude
Re: Diagram for 91 montero Throttle Position Sensor [Re: jetcitydude] #457594 06/02/04 06:28 AM
Tried the links that did not work.
Re: Diagram for 91 montero Throttle Position Sensor [Re: jetcitydude] #457595 06/02/04 06:42 AM
Vic,
Notice how your link says url=... that's not acceptable for the forum.
You have you have to get the url from the screen with a bunch of pics. (this one)
by right clicking on the image thumbnail and select "copy url".
Ray
Re: Diagram for 91 montero Throttle Position Sensor [Re: jetcitydude] #457596 06/02/04 09:02 PM
Vic Lee Offline
Jetcitydude:
Send me a PM with your email and I'll get those FSM diagrams to you.
I still can't figure out what is going on with the pics. I can get the links to work with the copy and paste, but can't seem to get it right even trying Ray's instructions.
Vic
1990 Montero 2dr 3.0 Auto Lsd Front & Rear
Re: Diagram for 91 montero Throttle Position Sensor [Re: jetcitydude] #457597 06/02/04 10:45 PM
Vic,
Not sure why it's not working on your post. I tried modifying your post personally and your right, it doesn't work.
I did work when I reposted it myself. Maybe it has to do with modifying a post with a pic, or having a non working image url with a working url.
I modified this post and added your other links but realized that they werent the correct link. Interestingly enough when I did that, the one that did work stopped working. When I removed the invalid image url's the valid one worked again. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Diagram for 91 montero Throttle Position Sensor [Re: off-roader] #457598 06/03/04 12:58 AM
Vic Lee Offline
Just started over..... Ray, Thanks for your posting help.
Vic
Re: Diagram for 91 montero Throttle Position Sensor [Re: jetcitydude] #457599 06/08/04 02:23 AM
Vic, thanks for the diagrams. That help alot. I thought I had all my codes cleared. Got a new one today. Vehicle speed sensor Code 24 no voltage change of vehicle speed sensor signal. So thanks again. I am still looking for that 90-91 manual. <img src="/forums/images/graemlins/cheers.gif" alt="" /> Vic, anyway you can put that 90 FSM on CD?
Re: Diagram for 91 montero Throttle Position Sensor [Re: jetcitydude] #457600 06/08/04 04:02 AM
Vic Lee Offline
Jetcitydude,
Glad that I could be of some help. I have the 90 Montero original FSM, and I donÆt want to cut it up to scan the whole thing. Happy to scan an occasional page or two if needed.
Would you recommend ECUdirect over Avpro? I need to send out the ECU out of my 90 and have it repaired.
Vic
PHP: 7.4.33 Page Time: 6.606s Queries: 16 (6.602s) Memory: 0.6380 MB (Peak: 0.7639 MB) Data Comp: Off Server Time: 2026-10-24 05:39:09 UTC
