'84 carb, CA emissions -> '87, carb, non-CA emissions...swap #457851 06/01/04 04:53 AM
MAXWELL Offline OP
Has anyone done something similar to this? I have verified many of the electrical connectors are the same, although there's a couple that are different. I only have the 1984 Toyota manual.
Re: '84 carb, CA emissions -> '87, carb, non-CA emissions...swap [Re: MAXWELL] #457852 06/01/04 07:29 PM
randito Offline
I have both an '85 22r non-CA and an '84 22r CA and know that the the wiring into the fuse box is a bit different. Think my '84's got 2 fusible links while the '85's got 3. I don't think that it would be too difficult especially if you've got all the connector's and wiring from the donor.
1985 runner, completely stock(still)
Re: '84 carb, CA emissions -> '87, carb, non-CA emissions...swap [Re: randito] #457853 06/01/04 09:26 PM
If I did it i would use all the original motors emissions etc stuff, and not register it as a change of motor.
Jay
PS, but for the effort why not just put a 22RE??? or a 22RET
Re: '84 carb, CA emissions -> '87, carb, non-CA emissions...swap #457854 06/08/04 04:39 AM
MAXWELL Offline OP
Because Engbldr down the road recommended using the '87 block. It will have a mild cam & OS valves when he's done with it.
I live in Multnomah county, Oregon (Portland) so I have to deal with emissions test. Both vehicles have gone through DEQ and the limits and tests...are EXACTLY the same. I just wonder if they require that the OEM smog equipment has to coincide what that sticker says placed underneath the hood. I went through what the VIN #s mean on both vehicles awhile back and I don't recall smog equipment being part of the information in the VIN#.
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.012s) Memory: 0.5959 MB (Peak: 0.6533 MB) Data Comp: Off Server Time: 2026-07-16 03:26:47 UTC
