3vze thermostat seal? #459379 06/04/04 03:28 AM
E
eep Offline OP
I replaced the thermostat on a 94 v6 runner a few months ago and it started leaking recently. Do you guys have any tips on how to seal it when I reinstall?
Re: 3vze thermostat seal? [Re: eep] #459380 06/04/04 04:45 AM
Robinhood150 Offline
That's what happened when I replaced my thermo...turns out it was actually the waterpump leaking. Might want to check that out.
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
Re: 3vze thermostat seal? [Re: Robinhood150] #459381 06/04/04 08:39 AM
E
eep Offline OP
I haven't checked the water pump for leakage. I did replace that at the same time I replaced the thermostat. But I can clearly see signs of leaking (dried up coolant) around the thermostat.
What did you use for the seals? I think the stuff I used was Permatex.
Re: 3vze thermostat seal? [Re: eep] #459382 06/04/04 06:18 PM
code33 Offline
Isn't there an O-ring to seal the housing?
Re: 3vze thermostat seal? [Re: code33] #459383 06/04/04 06:32 PM
Yeah, extra sealant *shouldn't* be needed since the o-ring around the thermostat seals it all up.
Steve
Re: 3vze thermostat seal? [Re: code33] #459384 06/04/04 06:41 PM
E
eep Offline OP
I don't remember now...maybe I was thinking about the water pump or one of the pulley assemblies with the water spout in it. I guess I'll take it off and check the o-ring. thanks
Re: 3vze thermostat seal? [Re: eep] #459385 06/04/04 06:51 PM
merikgvr4&sr Offline
Good luck EEP. Lemme know if you need help. <img src="/forums/images/graemlins/cheers.gif" alt="" />
e-rox
89 Malljero 4dr V6
94 Monstero SR (sold)
91 GVR4 turbo powa too many mods
83 300TD turbo diesel powa
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6173 MB (Peak: 0.6909 MB) Data Comp: Off Server Time: 2026-06-20 17:40:28 UTC
