Page 3 of 5 1 2 3 4 5
Re: The Skinny on the 3.4L motor swap.....WARNING...this is very long. [Re: Greg_Canada] #460152 06/09/04 04:23 AM
Ditto on the 3.0L paperweight. I paid to have a 3.4L put in and the shop couldnÆt dump the old motor for anything. Great write-upà lets me know I did the right thing letting someone with time and patience put the 3.4L in for me. Besides the wife says I gotta work on the house, not the truck when IÆm home. So I wheel, climb and try to avoid hanging around the house too much. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: The Skinny on the 3.4L motor swap.....WARNING...this is very long. #460153 06/10/04 02:37 AM
914Runner Offline
Hey 93CoRunner, when you get the chance could you post the info on getting the tach to work? My swap has been done and running great for about 2 months now but I have no tach!
Thanks a ton!
1991 Toyota 4Runner 4 Door, 3.4l 5VZ-FE Engine Swap, R150F 5-Speed Manual, 4WD, 4.10's
My Rig
Re: The Skinny on the 3.4L motor swap.....WARNING...this is very long. [Re: 914Runner] #460154 06/10/04 05:41 PM
I'll have to crack open my dash and take a picture of it first. which I'll need to do sooner or later to fix my oil pressure gauge.
It's easy to do. Just solder a 10K ohm resister onto the back of the tach circuit board just like the 3.4L tach has.
I've been conned into giving up all my pictures, diagrams and info for a technical article on here (4x4wire) so give it some time and it will all be posted in that article.
Re: The Skinny on the 3.4L motor swap.....WARNING...this is very long. #460155 06/11/04 06:08 AM
914Runner Offline
My oil pressure gauge doesnt work either, and I read somewhere that another guy's oil pressure gauge doesnt work after he did the swap. So im not sure whats up with the oil pressure gauge.
Thanks
My Rig
Re: The Skinny on the 3.4L motor swap.....WARNING...this is very long. [Re: 914Runner] #460156 06/11/04 06:43 AM
CORunner93 Offline OP
You probably did the same thing I did.....left the 3.4L oil pressure sending unit in and burned out your oil pressure dash gauge. I was able to get mine to work a little....which is to say the needle moves a little, but that's about it.
The two sending units (and therefore gauges) work differently. The 3.4L sending unit will send a full 12 volts to the gauge and that will cause the needle to go all the way right and bend a thin metal strip in the gauge. Once it's bent the gauge is pretty much gone.
I've heard of a one guy who had some success in re-bending the strip, but I failed.
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: The Skinny on the 3.4L motor swap.....WARNING...this is very long. [Re: 914Runner] #460157 06/11/04 07:42 AM
bwhitehead Offline
Thanks a ton!
914Runner send me an email and I will send you a photo on how to do the tach mod tomorrow.
bcwhitehead1@comcast.net
93 4Runner 3.4 swap, SAS, 37 Mtr, 5speed swap, High pinion ARB Front an Arb rear, ARB air compressor, Marlins Dual cases, bud built crossmemeber, 63 leaf spring swap. Sky rear disc conversion and the money keeps flowing!
Re: The Skinny on the 3.4L motor swap.....WARNING...this is very long. [Re: CORunner93] #460158 06/11/04 07:50 AM
bwhitehead Offline
Hey CO93Runner Good Job on the write up. The only thing that could be added is the dip stick relocation and pluging of the old port. Can't wait to see the article.
Brandon
Re: The Skinny on the 3.4L motor swap.....WARNING...this is very long. [Re: bwhitehead] #460159 06/11/04 04:32 PM
Thanks...
yeah....I was sure I was going to miss something. Feel free to add anything else I missed. I'm really not going to be doing the write up. One the the 4x4wire editors is, my pics and info will be in it and a lot of the info from the little write up I did probably. Should be pretty cool.
Just wish it was here before I did my swap. Still fun to do.
.....and thanks for all your help
Re: The Skinny on the 3.4L motor swap.....WARNING...this is very long. #460160 06/14/04 05:26 AM
914Runner Offline
So do you have to swap out the 3.4L oil pressure sender for the 3.0L one?
Thanks
EDIT: went back and re-read the original post, and that answered my question.
Thanks
My Rig
Re: The Skinny on the 3.4L motor swap.....WARNING...this is very long. [Re: 914Runner] #460161 06/14/04 07:03 AM
yes...use the 3.0L temp sender or you will burn out your gauge, like I did
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6351 MB (Peak: 0.7576 MB) Data Comp: Off Server Time: 2026-06-07 04:11:38 UTC
