Factory Trailer Wiring #462620 06/11/04 04:53 AM
Hey! How's everyone doing? Haven't posted in a while, but I just spent 2 hours catching up.
I just purchased an 18.5' Stingray boat and when I went to pick it up at the dealer, I noticed that the trailer's passenger-side turn signal wasn't working. I just figured it was a bulb, but I took a voltmeter to it and I'm not getting any voltage on the far-right pin of the trailer plug. Left turn signal works, parking lights work on both sides, brake lights work only on the left. All lights are functioning properly on the 4Runner. Does anyone have an electrical diagram of the factory trailer wiring?
The last electrical-related modification I made was probably the turn signals on the TJM bumper, but like I said, all of the lights are functioning properly on the 4Runner. I also have front IPFs, rear IPFs, and the electric locker wiring... but these *shouldn't* have anything to do with the right turn-signal not working on the trailer wiring.
Re: Factory Trailer Wiring #462621 06/11/04 05:35 AM
I dont know the colors off hand but if it helps I know most trailers are wired the same, with the same colors on the same side and such.
I assume you have taken that volt meter to the wiring harness and looked at the connection there.
Re: Factory Trailer Wiring #462622 06/11/04 05:57 AM
azrain Offline
Unplug the harness and check resistance on the trailer harness. Broken wire maybe? Is it a factory harness or aftermarket?
I should go back and clean up my own install a little as I have a couple of sharp bends I need to tidy up a bit...
Mike
Re: Factory Trailer Wiring #462623 06/11/04 11:51 PM
Marc M Offline
Is it a new boat and trailer ?? If not, may be corrosion in the trailers harness ???
'06 Tacoma Dbl-cab, 4X4, V6, 6-spd, SR5/TRD....
'90 4Runner 4X4 SR5 5-Spd
'86 Shortbed 4X4 5-Spd, SAS'd ASAP
'82 Supra 5-Spd
Take your automatic and "Stick" it........
My Web Album in Progress
Re: Factory Trailer Wiring [Re: azrain] #462624 06/24/04 04:57 AM
OK I've poked and prodded with the voltmeter and am now confident that the culprit is the "15 AMP TAILLIGHT CONVERTER AUTO CIRCUIT PROTECTION" module that is located on the inside of the rear interior panel, behind the driver's side taillight. There's voltage going into the converter, and voltage coming out - except for the right signal line. I've searched for the part and can't find it anywhere. The dealers don't sell it separately, but is included in the trailer wiring kit from Toyota for $190!
Any ideas? I'd like to keep it Toyota if possible... Would anyone who has removed their factory hitch be willing to sell me their converter?
Thanks.
<img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Factory Trailer Wiring #462625 05/04/06 04:53 AM
dscottjr Offline
I just found mine has the same problem. What did you end up doing?
Re: Factory Trailer Wiring [Re: dscottjr] #462626 05/04/06 07:26 AM
kewlynx Offline
Those converters go out all the time; always has been a problem. NAPA and other places carry the converter; not sure if you can get them without buying a whole trailer wiring kit or not tho'. ASK. Haven't had trouble with mine, and I don't use those stupid blue foldover splices either.
OR www.car-part.com for junkyarding for a Yota one.
**ubi apis- ibi salus**
Re: Factory Trailer Wiring [Re: kewlynx] #462627 05/04/06 02:43 PM
dscottjr Offline
Do the Napa replacements fit the Toyota connectors or do you have to run new pieces to each of the rear lights?
Thanks for your response:-)
Re: Factory Trailer Wiring [Re: dscottjr] #462628 05/05/06 05:58 AM
kewlynx Offline
I went to Radio Shack and got myself a terminal block and set it up that way. It's been awhile; seems I did some surgery on em and did a little solder and heat shrink.
If you need an FSM for wiring diagrams, we've got them in the Taco section and in the early trucks section.
If all else, the little troubleshooting light poked thru the insulation while activating the various lights works too.
Look 'em over and see what works for you.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6200 MB (Peak: 0.7221 MB) Data Comp: Off Server Time: 2026-06-10 07:18:06 UTC
