Page 4 of 6 1 2 3 4 5 6
Re: What's the most miles you have on your original engine? [Re: kyle-22r] #462976 06/15/04 01:35 AM
boosted3g Offline
i have an 88 xtra cab wtih 222,000 miles on the original 3.0. The oil pressure dont get into the normal range on the gauge until it gets over 3k but somehow it still keeps on going. Maybe next oil change ill change the filter too not just the oil. I love my beater.
Re: What's the most miles you have on your original engine? [Re: Staceman] #462977 06/15/04 02:33 AM
A friend of mine has an '88 pickup at around 220k with not much maintenance. Still on the original timing chain. <img src="/forums/images/graemlins/shocked.gif" alt="" /> I've told him MANY times he's living on borrowed time.
Re: What's the most miles you have on your original engine? #462978 06/15/04 03:24 AM
98'000 on the original... I still have the long block in my garge, in still running condition with good compression... a good core I guess.
in the quest for more HP ya let it go with such low mileage?? anything wrong with the old motor.. BTW 2.6 sounds way better.. i have 159,000 on mine
Re: What's the most miles you have on your original engine? #462979 06/15/04 11:04 PM
only 133 so far... which is less than i put on my last truck in 3 years.
i'll be up around 200 in a year or so, then we'll talk! so far, so good.
Re: What's the most miles you have on your original engine? #462980 06/16/04 12:59 AM
soundguy Offline
Just turned 200,365K on my 3.0. It is my daily driver and aside from some timing belts and a water pump, bored T-Body, wires, plugs....standard tune-up stuff - it is essentially the same as driving it off the lot with 22 miles on it. Granted I now have a leaky rear main seal and a #6 that has a leaky valve guide - but it is holding on nicely.
'95 4 Runner SR5 3.0L 4x4 , A/T, D.O.A. bored T-body, K&N Filtercharger.....
Re: What's the most miles you have on your original engine? #462981 06/16/04 07:28 AM
BennyBoy Offline
85 with 355,000. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: What's the most miles you have on your original engine? [Re: BennyBoy] #462982 06/16/04 05:14 PM
A
averkam Offline
156,000 - burnt valve - head job
169,000 currently all stock other than the heads.
2000 Ext Cab SR5 4WD 2.7L 5-speed.
Re: What's the most miles you have on your original engine? #462983 06/16/04 05:39 PM
pigota Offline
Lets see, about 175,000K showing on the odo on my 84 22R 4x4. Timing set and head rebuilt at 166,000. <img src="/forums/images/graemlins/oink.gif" alt="" />
fast enough to beat its own shadow
Re: What's the most miles you have on your original engine? [Re: pigota] #462984 06/16/04 09:43 PM
88Runnerv65spd Offline
Just hit 300000 today. alternator/starter and power steering pump rebuilt. Just normal maintenance. Took a pic of it...just dont know how to post it <img src="/forums/images/graemlins/confused.gif" alt="" />
Is there a 300000 mile club?
Gary S.
88 Runner SR5 V6
Re: What's the most miles you have on your original engine? [Re: 88Runnerv65spd] #462985 06/16/04 10:31 PM
kyle-22r Offline
i'm in it <img src="/forums/images/graemlins/shiner.gif" alt="" />
'91 4x4 shortbed
22R-E, W56, the dd!
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6334 MB (Peak: 0.7384 MB) Data Comp: Off Server Time: 2026-06-17 04:06:30 UTC
