big "oops"... rounded-off bolt #463391 06/13/04 04:17 AM
ecowheeler Offline OP
Does anyone have any suggestions on how to extract a rounded-off exhaust manifold bolt? Any help would be appreciated
My '86 4Runner went to the bone-yard November 29, 2004 at 10am after roughly 430,000 miles on the original engine and transmission. :-( Looking for something else to wheel in...
Re: big "oops"... rounded-off bolt [Re: ecowheeler] #463392 06/13/04 04:31 AM
TNToy Offline
Weld a nut to the head of the bolt, grind two opposite sides flat and use vise-grips on it... there a a couple of methods.
The tricky thing isn't that you can't get it out, it's that you can't get TO most of them to get fancy... <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: big "oops"... rounded-off bolt [Re: TNToy] #463393 06/13/04 07:06 AM
Not trying to divert from your problem, and not assuming you didn't try already, but
Next time you face removing rusted hex bolts/nuts use a quality 6 point socket. It's less likely they will round off the head flats.
Is the manifold still attached? Or is this a stud you are trying to remove from the head with the manifold already off?
Re: big "oops"... rounded-off bolt #463394 06/13/04 07:27 AM
kyle-22r Offline
i think i got lucky when i did my exhaust manifold. when i tore off the heat shield, there were only 2 studs still in there <img src="/forums/images/graemlins/shiner.gif" alt="" />
vise grips work pretty well, just clamp them TIGHT
'91 4x4 shortbed
22R-E, W56, the dd!
Re: big "oops"... rounded-off bolt [Re: ecowheeler] #463395 06/13/04 08:33 AM
Brian894X4 Offline
Also, use an extremely liberal amount of WD-40 or some kind of rust breaker fluid. It will definatley help.
Re: big "oops"... rounded-off bolt [Re: Brian894X4] #463396 06/13/04 08:43 AM
CORunner93 Offline
Heat it with a torch....even a propane torch will work if you hold the flame there long enough.
Metal expand when you heat it (obvioulsy). So heat the nut and not the bolt....works like a charm every time.
Be carefull not to light anything on fire though.
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: big "oops"... rounded-off bolt [Re: ecowheeler] #463397 06/15/04 01:03 AM
bosmanstt Offline
These bolt extractors worked great for me:
www.irwin.com
Re: big "oops"... rounded-off bolt [Re: Brian894X4] #463398 06/15/04 01:47 AM
Myota Offline
PB Blaster works for me!
-Chris
'88 EFI Xtracab, 32 x 11.50 Buckshots, AZ bed, Turbo drivetrain.
Re: big "oops"... rounded-off bolt [Re: Myota] #463399 06/15/04 02:47 AM
thanks for all the tips... PB catalyst and a 6 point(rather than a 12 point) socket did the trick
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6253 MB (Peak: 0.7116 MB) Data Comp: Off Server Time: 2026-06-20 17:41:16 UTC
